the back end it to low down
and the front is to high
it would look good just add a bit packaging under the cab
you cant mate, the arches on these are screwed into place from insdie the chassis and also held by a rod through them and the chassis block at the rear, its not the normal britains style 1 peice moulded palstic you see
no, i wish i just thought that the front of the tractor was a little high,  i like the oscilating movement and the ackerman steering though  at least i think that is the correct description for this type of steering
