jim deere Posted January 25, 2009 Share Posted January 25, 2009 she looks absolutly fantastic :o Quote Link to comment Share on other sites More sharing options...
Barry Posted January 25, 2009 Author Share Posted January 25, 2009 Will you be raising up the weight block mate? Like the EU spec ones? Have looked at that, made a basic block but not happy wih it, will make another one and fit Also looking to make the Laforge front linkage for another 8400 to do later Quote Link to comment Share on other sites More sharing options...
flash 600 Posted January 25, 2009 Share Posted January 25, 2009 nice job barry looks really well you are truely gifted 8) Quote Link to comment Share on other sites More sharing options...
jdc Posted January 25, 2009 Share Posted January 25, 2009 Another great step by step, with an impressive end result. What an improvement. Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted January 26, 2009 Share Posted January 26, 2009 why are the front weights up higher on euro versions then compaired to usa versions??? Quote Link to comment Share on other sites More sharing options...
MDFord Posted January 26, 2009 Share Posted January 26, 2009 why are the front weights up higher on euro versions then compaired to usa versions??? Because the European weights are a different shape - with the mounting point higher up \ Quote Link to comment Share on other sites More sharing options...
Jez Posted January 26, 2009 Share Posted January 26, 2009 Because the European weights are a different shape - with the mounting point higher up \ I think that is right Mark. Also the UK tractors need better ground clearance. I think it also comes down to complete machine set up, e.g you can leave front row crop duals in america and head off down the road, the extra wheels give for a bit more weight....... Hence the European ones have more weight to hang on there too. Quote Link to comment Share on other sites More sharing options...
deere6920s Posted January 26, 2009 Share Posted January 26, 2009 What a beauty!!! I think you can use the rear wheigts of the JD SPFH. Quote Link to comment Share on other sites More sharing options...
Ziko Posted January 26, 2009 Share Posted January 26, 2009 This an great 8400! One the best I have seen so far I guess! Great work! Have looked at that, made a basic block but not happy wih it, will make another one and fit Also looking to make the Laforge front linkage for another 8400 to do later I have such weights for sale, if you are interested just send me a PM ;P Quote Link to comment Share on other sites More sharing options...
Simon Posted January 26, 2009 Share Posted January 26, 2009 Christ Barry, I've just read this through, when I first read 'the exhaust's broken so thought I'd change the spec' I thought something minor, like glue the exhaust back on and take some indicators off.... not take it all apart and rebuild the whole thing! But well worth it mate, looks incredible.... How come this one on the drill has no mirrors.... Is it pre-prod or summint Or just a really bad driver.... \ [er, no comments about missing door mirror either ] Quote Link to comment Share on other sites More sharing options...
Johny mf Posted January 26, 2009 Share Posted January 26, 2009 A great good looking model turned to a much more great good looking model Job wel done Barry Quote Link to comment Share on other sites More sharing options...
Barry Posted January 29, 2009 Author Share Posted January 29, 2009 The rear wheels were from the Ertl 8430, not the Britains JD from the 1970's The picture shows the outer wheel, i used the inner ones Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted January 29, 2009 Share Posted January 29, 2009 The rear wheels were from the Ertl 8430, not the Britains JD from the 1970's The picture shows the outer wheel, i used the inner ones what will you do with that one now barry, can you sort replacement wheels for it?? Quote Link to comment Share on other sites More sharing options...
Barry Posted January 29, 2009 Author Share Posted January 29, 2009 I've seen picture of the 8430 with these outer wheels on as single wheels tractors, so put them back on and sort out some front wheels. The front wheels are held on with a screw and a small washer in the inner wheel, the inner wheel is no good to use as a front wheel so will have to find a way of fitting a front wheel on, or adapting those to fit. Quote Link to comment Share on other sites More sharing options...
jd boer Posted January 30, 2009 Share Posted January 30, 2009 i have here also that model , but how can you take off te front tyres from the steer as sorry for my bad english Quote Link to comment Share on other sites More sharing options...
Barry Posted February 1, 2009 Author Share Posted February 1, 2009 Received this lovely set of weights from Ziko on Friday, so set about fitting it to the 8400 I decided not to use the weight block provided, but to make my own, as shown on the real tractor in the photo above I cut the front of the 8400 Then added the weight block and weights Also added some lights above the weights Side view I might put the towing pin in the weight block too, when i find a small enogh drill bit Quote Link to comment Share on other sites More sharing options...
Kiwi6920 Posted February 1, 2009 Share Posted February 1, 2009 Lovely barry. that is a cracking job you have done, i couldnt bring myself to do that to one of those knowing how hard they are to get .... Quote Link to comment Share on other sites More sharing options...
Ziko Posted February 1, 2009 Share Posted February 1, 2009 I can't see the pics? Quote Link to comment Share on other sites More sharing options...
Barry Posted February 1, 2009 Author Share Posted February 1, 2009 I can't see the pics? Should be up now Ziko, i moved the pictures in Photobucket so there address was different, all a learning curve! Quote Link to comment Share on other sites More sharing options...
Ziko Posted February 1, 2009 Share Posted February 1, 2009 I can see them now! Looks very nice, your self made holder is spot on! Quote Link to comment Share on other sites More sharing options...
Deere-est Posted February 1, 2009 Share Posted February 1, 2009 Yet to see a better one, that's superior. Quote Link to comment Share on other sites More sharing options...
The Tractor Twitcher Posted February 1, 2009 Share Posted February 1, 2009 Stunning work Barry, very impressive machine Regards David Quote Link to comment Share on other sites More sharing options...
Johny mf Posted February 1, 2009 Share Posted February 1, 2009 Wat a great looking tractor it is now after all those chainges Quote Link to comment Share on other sites More sharing options...
texas Posted February 1, 2009 Share Posted February 1, 2009 The john deere is looking great Barry. texas Quote Link to comment Share on other sites More sharing options...
Jez Posted February 2, 2009 Share Posted February 2, 2009 Fantastic mate! Quote Link to comment Share on other sites More sharing options...
