casting-can you help
as you all know im currently doing a ford ap cab.i was wondering if anyone can help me getting it cast,or put me on the right track.if someone would be willing to help im sure we can come to some arrangement.thanks in advance
2 answers to this question
ive never done one before but i recon
you will need a two bit mould
shore up your windows in the cab you want to cast (needs to be shored up to stop rubber getting out) then fill it with synthetic rubber
so you now have an inner mould then
do an outer mould  by placeing the cab in a small box with roughly 2-3cm space
around the outer cab frame (still needs to be shored up to stop rubber getting in )
you now have two moulds ...an outer and inner mould
pour resin into the outer mould then push down your inner mould to push the exes resin out and leave for
roughly half an hour to go off
i think its called "squidge moulding"
there may also be tutorials on moulding or "squidge moulding" on youtube.com
hope this helps  mate
Edited for Text Talk!!
i have done moulds for 3 cabs now mate, and its not the easyst of items to do, pm me if you want and i can sort of expalin it to you, its similar to what nig said, but a few extra tips may be needed
