MODELFARMER Posted March 24, 2009 Share Posted March 24, 2009 Ok, We bought one of these in Jan, Has anyone got one and had problems with it?? If so care to share them here with me? I'll tell you shortly what ours has been doing wrong but i want to see if anyone has encountered this also before i ring nc and tell them to lift the whole thing and refund it Ricky Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 24, 2009 Share Posted March 24, 2009 we bough ours second hand of the dealers, they used it themselves. they put a new blade on the box. But the second time we used it the hydraulic motor went, mechanic tried telling us we were changing direction to fast, which he was wrong because my we flicked the stopper over so the lever could only go forward in the tractor :P Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 24, 2009 Author Share Posted March 24, 2009 Hmmmmmmmm Interesting, its the motor giving bother on ours Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 25, 2009 Share Posted March 25, 2009 Hmmmmmmmm Interesting, its the motor giving bother on ours is it only working when it wants to ours did that before it stopped altogether Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 26, 2009 Author Share Posted March 26, 2009 Ok when its out onto the ground running, it goes for a short time few secs . . .then stops it won't drive (as if it has not enough power to turn) it will not reverse full stop NC Came up put on a used motor (cheeky f*c*s) it should have been a brand new one!!! this one dont reverse either but it brushes forwards perfect, maybe something to do with the check valve ontop of motor? Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 26, 2009 Share Posted March 26, 2009 You can try the valve if you want \ we did, we took the whole thing apart, because it just seemed like something was jammed and stopping the oil \ but no the motor was buggered \ For us it didnt matter wether it was on the ground or up, it would go for a few secs then it knock the hyd lever off itself \ Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 26, 2009 Author Share Posted March 26, 2009 You can try the valve if you want \ we did, we took the whole thing apart, because it just seemed like something was jammed and stopping the oil \ but no the motor was buggered \ For us it didnt matter wether it was on the ground or up, it would go for a few secs then it knock the hyd lever off itself \ Had it off on original motor no difference dunno about this motor though Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 26, 2009 Share Posted March 26, 2009 probably best just to get a brand new motor \ it sounds like the same sort of thing as us, and the new motor sorted it if i remember right it may have been the seals that went inside it, you could fry an egg ontop of that motor after about a minute, not surprising something gives \ Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 26, 2009 Author Share Posted March 26, 2009 ONLY BOUGHT THE BLOODY THING IN JAN ITS WARRENTY BUT NC ARE HARD WORK!! Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 26, 2009 Share Posted March 26, 2009 :D if you didnt have bad luck youd have no luck at all :D are you working directly with NC Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 27, 2009 Author Share Posted March 27, 2009 :D if you didnt have bad luck youd have no luck at all :D are you working directly with NC YES Dealer was beat so nc wanted to look themselves not much use Quote Link to comment Share on other sites More sharing options...
nashmach Posted March 27, 2009 Share Posted March 27, 2009 Ricky, tell NC you are not happy with it and you want your money back unless they fit a new motor of your choice otherwise they have already broken the guarantee putting a second hand motor on it Quote Link to comment Share on other sites More sharing options...
Stuarty C Posted March 27, 2009 Share Posted March 27, 2009 Tell them redrock are quoting you a good price Quote Link to comment Share on other sites More sharing options...
jdc Posted March 27, 2009 Share Posted March 27, 2009 Just out of curiosity, are you running it back through the spool or a free return? Quote Link to comment Share on other sites More sharing options...
Lord Ferguson Posted March 27, 2009 Share Posted March 27, 2009 Just out of curiosity, are you running it back through the spool or a free return? That's just what I was thinking John... It should be piped directly into the back end... through a coupling with no srping in it too.. or a big bugger like my baler I reckon Ricky Quote Link to comment Share on other sites More sharing options...
Deeredriver Posted March 27, 2009 Share Posted March 27, 2009 Kind of hard to get it to run backwards though with one hose direct into the tractor rear end Quote Link to comment Share on other sites More sharing options...
Lord Ferguson Posted March 27, 2009 Share Posted March 27, 2009 Kind of hard to get it to run backwards though with one hose direct into the tractor rear end Oh I see.... so it goes on to a double acting spool then does it ummm.. sounds like a strange one to me that then... when you see the hole in a coupling even fully open it's easy to undrstand why the oil heats up through them :o Quote Link to comment Share on other sites More sharing options...
Deeredriver Posted March 27, 2009 Share Posted March 27, 2009 yes i know what you mean on oil heating up i think they are kind of thinking that it will be used off and on and not constantly running like a hyd motor on a fert spreader disc or a planters motor running the vacuum i run a tub grinder and the 20 ft delivery belt is run by a hyd motor that run off the double acting hyd remotes on tractor never had any bother with that and thats under a high rpm and high load too Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 28, 2009 Author Share Posted March 28, 2009 It made no difference weather it into the spool or back end, SO dealer mechanic appeared today He removed the check valve block on the brush (i did do this with original motor made no difference) now the current motor works 100% So dealer is basically telling NC to f888 up and send up a brand new motor Quote Link to comment Share on other sites More sharing options...
Coxy Posted March 28, 2009 Share Posted March 28, 2009 you shoud of brought a suton sweeper Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted March 28, 2009 Author Share Posted March 28, 2009 we had a bema and a fleming linkbox, stone fork so hadn't much use for linkbox, dealer gave us the same money as a new linkbox for ours and gave us crazy good money for our bema, it was worn done really too so thats why we bought the nc, Just this temp motor on it now and its going great but i have a modification i want to carry out, will show youwhen i'm doing it Quote Link to comment Share on other sites More sharing options...
TM190 Posted March 28, 2009 Share Posted March 28, 2009 we had a bema and a fleming linkbox, stone fork so hadn't much use for linkbox, dealer gave us the same money as a new linkbox for ours and gave us crazy good money for our bema, it was worn done really too so thats why we bought the nc, Just this temp motor on it now and its going great but i have a modification i want to carry out, will show youwhen i'm doing it Suppose the big hammer will be out :D Quote Link to comment Share on other sites More sharing options...
