kestler farm cornwall
graham
still running the other tractor we brought of you mark , wood wall sean is used in packaging normally on e bay it comes in differant colours but mainly straw colour there is brown and green that i know ,i mixed mine with brown for the dung effect ,it does need cutting fine thou ,
  • 3 weeks later...
thanks for replys ,mandy that is not the water trough it is the feed trough but like you say does look like algee ,it is just scatter mandy
been doing some more the old barn we had to put up old grain bins made out of weldmesh and tared paper ,i thought it was time to change this ,found some grain bins that where used in a seed plant down menheniot brought them back to kestler and with some cutting we got them to fit in the barn with some elevators and walkway ,got to put in roller mill ,still got some more to do but a few pics
Menheniot? I've been there in a Saxo, no problem. I also tried going there in a 44t artuc when I was on brick an block........ I was stuck in the lane for five hours  ::) :'( :laugh: Love that old stone building, very nice and typical of Cornwall too. Lovely jubbley, Graham  :)
thanks for the replys ,the buildings are made from 6mm mdf ,i try to mitre corners for better finish , i just use standard pollyfiller apply this to the buildings with a 1 inch putty knife some areas thicker than others with this type finish if i do brickwork i try to get to get it smoother , then i use some special tools a cocktail stick and a 3 inch nail to scribe in the effect i want , sometimes you have to wait until filler has started to dry out a bit trial and error , then leave to dry then brush to clean any loose bits of ,then i paint on neat pva to seal the filler leave to dry ,paint the colour you need .then i get a small brush and in the groves that you made with the special tools paint in neat pva and i add concete dust for cement [ i do a lot of concrete drilling with my work and with my anorak on i collect the dust that i make it is cheaper than the packs of scatter] but painting will give you same effect  hope this helps a bit  ;)
fantastic as usual graham a master at work ........looking forward to every update
Puts me to shame just trying to get a basic shed started with benjamin at the minute a expert with glue (putting it everywhere except on the barn)
hopefully will get it finshed for tractor world
just had a load of fert turn up he rang earlier and said he was coming down from kent ,so driver is having tea with us we unload him tommorow morning early then he down to par docks for a load home ,
dogs pleased to see him and check the tryes out
