Hinges for plasticard gates
piper.28
You could try what I have done in the past with Britains lead gates and posts hinges. Drill a tiny hole in both the gate and the hanging post where the old hinges would have lined up, cut a short length of brass or steel wire of the desired diameter to fit tight in the drilled post and bend to a right angle to form the hangers, push into the drilled hole after applying a spot of super glue in the holes. For the gate, use the same brass or steel wire and with a small pair of pointed nosed pliers form a ring eye one end of the wire and fit into the gate end the same as the post.
There are hinges ready made out there from aircraft wings, I can't for the life if me remember the name of them but I have some.... in the attic! There are two or three different sizes and types, grey plastic. The only trouble I found was they did not glue very well with the glue I used anyway :of
i just found some small hinges that i think may do the job for drop side trailers, so will order some to try, at £2.79 plus 99p postage for 10  i cant really loose
Do you have a link Sean?
