a quick conversion
i would like to see if i can can get some siku jd 6920s wheels for it because then i can put them back on my fendt so if any one has got a set of 2 front wheels and 4 rear wheels and also the axles for them with the longer rear axel so i can put duels aswell as the standed one so i can choose what i want on them
i fitted britains wide flotations to the front of my 6200 jd (with help from DT) you get the old type hollow plugs (britains sanderson forklift etc) drill them out abit in the centre, glue a flat washer to the back of the tractor stub, place the wheel on then press the plug on (pace a drop of glue into it first) and there you have it new wheels fitted onto a ertle axle, this idea may look well on your tractor with having duels on the back.
 Share
