Guest Fendt pwr Posted April 17, 2006 Report Share Posted April 17, 2006 2 axle flat deck trailer I've made. I need to work on the draw bar a little more so it will fit my wee UH tractor a bit beter.I tryed to make the draw bar to fit a UH tractor but it wants a mm or 2 off the under side so that it will make sharpe turns beter. Quote Link to comment Share on other sites More sharing options...
NewHolland2 Posted April 17, 2006 Report Share Posted April 17, 2006 Looking good Oli. Will it be for carting tattie boxes? Quote Link to comment Share on other sites More sharing options...
Guest Fendt pwr Posted April 17, 2006 Report Share Posted April 17, 2006 Just a hay trailer mate,I would'nt cart my precious tatties on any thing I've made. Quote Link to comment Share on other sites More sharing options...
NewHolland2 Posted April 17, 2006 Report Share Posted April 17, 2006 Just a hay trailer mate,I would'nt cart my precious tatties on any thing I've made. Will look good fully loaded with bales mate. Quote Link to comment Share on other sites More sharing options...
JC Posted April 17, 2006 Report Share Posted April 17, 2006 Tidy job Ol. Quote Link to comment Share on other sites More sharing options...
jdc Posted April 17, 2006 Report Share Posted April 17, 2006 Nice one FP. You better get that bale lifted quick before the wooly vermin destroy it. Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted April 17, 2006 Report Share Posted April 17, 2006 I htink its winter and they need the bale to eat, hence the hay trailer to take the bales to the field Quote Link to comment Share on other sites More sharing options...
IH885XLMAN Posted April 17, 2006 Report Share Posted April 17, 2006 Im after any pics of a trailer similar to the one pictured but the bodey sits lower into the axel only a single axel and the axel is half way upthe body length but i like your trailer FENDT POWER Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted April 17, 2006 Report Share Posted April 17, 2006 nice one oli looks great Quote Link to comment Share on other sites More sharing options...
NCC Posted April 17, 2006 Report Share Posted April 17, 2006 Good work Oli, would make a good drag for a hay/straw truck wouldn't it ??? ;) Quote Link to comment Share on other sites More sharing options...
FB Posted April 17, 2006 Report Share Posted April 17, 2006 nice work Oli, just need to dirty up the wood a little :) Quote Link to comment Share on other sites More sharing options...
JC Posted April 17, 2006 Report Share Posted April 17, 2006 Good work Oli, would make a good drag for a hay/straw truck wouldn't it ??? ;) I thought that too with it having the long drawbar. Quote Link to comment Share on other sites More sharing options...
FB Posted April 17, 2006 Report Share Posted April 17, 2006 Oli, how did you make the 'foot' Quote Link to comment Share on other sites More sharing options...
Guest Fendt pwr Posted April 17, 2006 Report Share Posted April 17, 2006 Thanks guys :) FB,I made it out of 2mm plastic sheating(painted silver).I super glued the 3 small bits together then slipped it on to the draw bar and drilled a 1mm hole through the hole stand and the draw bar.It's got a cut down paper clip through it so it will swing.You just push the stand down then back up a few mm's and the draw bar lifts it self up then just drop the hitch and drive out.So simple even Ol could do it. Quote Link to comment Share on other sites More sharing options...
FB Posted April 17, 2006 Report Share Posted April 17, 2006 Thanks guys :) FB,I made it out of 2mm plastic sheating(painted silver).I super glued the 3 small bits together then slipped it on to the draw bar and drilled a 1mm hole through the hole stand and the draw bar.It's got a cut down paper clip through it so it will swing.You just push the stand down then back up a few mm's and the draw bar lifts it self up then just drop the hitch and drive out.So simple even Ol could do it. cheers oli, i'll try it one day Quote Link to comment Share on other sites More sharing options...
NCC Posted April 17, 2006 Report Share Posted April 17, 2006 cheers oli, i'll try it one day Will that be when pigs are flying :D ;) Quote Link to comment Share on other sites More sharing options...
FB Posted April 17, 2006 Report Share Posted April 17, 2006 Will that be when pigs are flying :D ;) yeah that and the day your not associated with pink in nearly every topic! :D ** must get thin plasticard Quote Link to comment Share on other sites More sharing options...
NCC Posted April 17, 2006 Report Share Posted April 17, 2006 yeah that and the day your not associated with pink in nearly every topic! :D ** must get thin plasticard I wish that day would come then and bl00dy quick too :D : Quote Link to comment Share on other sites More sharing options...
Guest Fendt pwr Posted April 17, 2006 Report Share Posted April 17, 2006 The mind boogles...... Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted April 17, 2006 Report Share Posted April 17, 2006 I'm confused again sorry Quote Link to comment Share on other sites More sharing options...
