alf aphid Posted January 26, 2016 Author Share Posted January 26, 2016 33 minutes ago, Tractorman810 said: Looking tidy to so far, are you sticking with the rear Celtics wheel on it ?? Or still looking for something similar to your pic at the start. Thank you No, the Celtis wheels were to give idea of diameter which are the same as my chosen wheel, which will be the replicagri RENAULT 751, it looks very close to the Deere item. Just the fronts to find plus the suitable axle, of which there have already been a few suggestions Link to comment Share on other sites More sharing options...
alf aphid Posted February 1, 2016 Author Share Posted February 1, 2016 Ok so I think the replicagri inter 845 looks like a good donor axle, does anyone have an unboxed or damaged model with a good front axle? The britains one is a bit lumpy especially with a smaller wheel fitted. wheel wise it's not quite right but I really can't find anything similar comments welcomed, it's all that's holding me back now, before the paint stage. Link to comment Share on other sites More sharing options...
alf aphid Posted February 21, 2016 Author Share Posted February 21, 2016 Well the international got it!!! Link to comment Share on other sites More sharing options...
alf aphid Posted February 21, 2016 Author Share Posted February 21, 2016 Axle fitted, front wheels are actually not a bad match if you leave the hubs off. Nearly ready for a bit of undercoat. Link to comment Share on other sites More sharing options...
Stabliofarmer Posted February 21, 2016 Share Posted February 21, 2016 This is looking superb! Link to comment Share on other sites More sharing options...
alf aphid Posted February 21, 2016 Author Share Posted February 21, 2016 21 minutes ago, Stabliofarmer said: This is looking superb! Thank you ! Not perfect, but pleased so far, quite keen to get painted Link to comment Share on other sites More sharing options...
mb86 Posted February 22, 2016 Share Posted February 22, 2016 12 hours ago, alf aphid said: Well the international got it!!! I wouldn't worry. Nash owners will be used to seeing them taken apart . Your JD is looking great. Link to comment Share on other sites More sharing options...
alf aphid Posted February 22, 2016 Author Share Posted February 22, 2016 3 hours ago, mb86 said: I wouldn't worry. Nash owners will be used to seeing them taken apart . Your JD is looking great. Ha ha thanks, I am feeling a little guilty! Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 22, 2016 Share Posted February 22, 2016 That's pretty spot on to your pic now, will you refit the original front hubs? Or make a new full wheel flat disc for it to hide the screw on the front axel, what are you doing with the left over replicagri ?? Sure someone could find a use for it? I could see a potential use for me already , but would never get round to it Link to comment Share on other sites More sharing options...
alf aphid Posted February 22, 2016 Author Share Posted February 22, 2016 2 hours ago, Tractorman810 said: That's pretty spot on to your pic now, will you refit the original front hubs? Or make a new full wheel flat disc for it to hide the screw on the front axel, what are you doing with the left over replicagri ?? Sure someone could find a use for it? I could see a potential use for me already , but would never get round to it Thanks tractorman, at the moment I'm going to leave the hubs off. They are actually not a million miles away from the real thing l think I will struggle to find anything closer. Making a flat disk, I think I'd struggle to pull off well enough. I may at this stage just fill the screws, the look will not be a million miles off I hope and I can always change at a later date if needs be. as for the inter, nothing planned with it at the moment !! . Link to comment Share on other sites More sharing options...
alf aphid Posted June 28, 2016 Author Share Posted June 28, 2016 Been a while, but short on time. Finished painting and now offered up for rough fitting, seems all roughly ok, not a masterpiece but I hope you can tell what it is. Would like to glaze the cab, will never look wonderful as pillars so thick being white metal. Hopefully be updated with finished article in a slightly shorter time frame!! Link to comment Share on other sites More sharing options...
Stabliofarmer Posted June 28, 2016 Share Posted June 28, 2016 Very nice indeed Link to comment Share on other sites More sharing options...
Tractorman810 Posted June 28, 2016 Share Posted June 28, 2016 Liking that a lot, very close to your first pictures . Link to comment Share on other sites More sharing options...
alf aphid Posted June 28, 2016 Author Share Posted June 28, 2016 Thank you both, still a little way to go but generally I think you can tell what it is - I hope !! Link to comment Share on other sites More sharing options...
alf aphid Posted July 16, 2016 Author Share Posted July 16, 2016 Well just managed to steal a rare couple of hours, ok not much to see but cab now glazed and stickers on. I will have another go at the front one, they are tricky to cut! Not too far to go now, biggest headache will be rear window which I thought fitted fine prior to painting, it certainly doesn't now few errors and inaccuracies but you get the idea. Link to comment Share on other sites More sharing options...
justy 46 Posted July 17, 2016 Share Posted July 17, 2016 Well done. Very nice classic convo. Link to comment Share on other sites More sharing options...
trigger82 Posted July 17, 2016 Share Posted July 17, 2016 Very nice work you did on this cab is good . Link to comment Share on other sites More sharing options...
0025 Posted July 17, 2016 Share Posted July 17, 2016 lovely work! Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 17, 2016 Share Posted July 17, 2016 thats probably one of the best tractor conversions i have seen, no oversized wheels and tyres and chrome etc ,just a nice proper looking vintage tractor Link to comment Share on other sites More sharing options...
BK741 Posted July 17, 2016 Share Posted July 17, 2016 Like it alot. Well done Link to comment Share on other sites More sharing options...
Valley Axe Man Posted July 18, 2016 Share Posted July 18, 2016 Sean probably hit the nail on the head with his post above, Nice to see a classic, great work Alf well done Link to comment Share on other sites More sharing options...
alf aphid Posted July 18, 2016 Author Share Posted July 18, 2016 Well gents thank you very much for the kind comments, I'm glad you approve! will update with the finished article soon I hope! Thanks again ☺️ Link to comment Share on other sites More sharing options...
alf aphid Posted August 1, 2016 Author Share Posted August 1, 2016 Well not quite finally glued together but lights and number plates added etc just a few touches left to complete. Link to comment Share on other sites More sharing options...
dm434 Posted August 2, 2016 Share Posted August 2, 2016 very smart , I like it Link to comment Share on other sites More sharing options...
chris.watson Posted August 2, 2016 Share Posted August 2, 2016 Great build, nice neat finish.well done. Link to comment Share on other sites More sharing options...
