This is a guide to casting Wheels and Tyres with Rubber Tyres. Very useful to avoid excess cost from breaking models for wheels, the skills are adaptable to other parts and I will try and add some photos of moulds for other parts and methods of how I've done them
The basic idea for the mould for both the rim and tyre is to create an all sided part that would normally require a two part mould from a one part mould. This reduces flash and requires less faffing in preparing the mould before each cast.
Starting with the rim
One short (5mm) length of plastruct tube is glued to the side of the rim. This is then glued to a piece of card. You may notice at this point some writing in reverse on the piece of card. This is to identify the mould once finished as I now have a large number of similar sized moulds this makes identifying the one I need a lot easier as the indent in the card will appear raised in the final mould, the silicone also picks up the pencil so the mould will have its name written in it permanently.
A sealed box is then built up around the rims, note they have been positioned at an angle with the front of the rim pointing slightly up, this will help avoid an air bubble forming under the lip of the rim when pouring the mould, a common issue I've had.
Now for the tyres
A circle approximately 8-10mm greater diameter than the tyre your casting is cut, the writing put on, remember to put it backwards or it'll be in reverse when you finish. Then a plastruct tube and piece of square (5mm long again) are glued to the bottom of the tyre and the tyre then glued on the the card circle.
A sealed box is then built up around it again, it is important that the box is sealed or the silicone will seep out.
I have then draw a circle on the card the same diameter as the centre of tyre, this will be left in the mould and provide a guide for where to cut to remove the tyre later
The method is appropriate for any style and size of tyre, for larger ones you may wish to increase the size of the circle around the tyre to give the mould abit more strength
Stabliofarmer
Continuing on from here
Now for the tyres
We're now ready to pour
18 answers to this question
