L33 DA17ON Posted June 17, 2020 Share Posted June 17, 2020 That looks a good size area you have. Be nice to see what you do with it. I've found grouting works well if you get the flexi stuff it goes off fast as well east to miss a d work with you could get loads of different finishes and could scribe it the day after as its still soft. Link to comment Share on other sites More sharing options...
Ferret90 Posted June 17, 2020 Author Share Posted June 17, 2020 6 hours ago, L33 DA17ON said: That looks a good size area you have. Be nice to see what you do with it. I've found grouting works well if you get the flexi stuff it goes off fast as well east to miss a d work with you could get loads of different finishes and could scribe it the day after as its still soft. That sounds good might have to have a go at that, you’ve got your concrete spot on. This is my attempt, plaster, sand, pigments and water. I put some mesh fabric to bind it all together so it can be broken up. Then sanded it all down. Next time I think I’m going to make it a bit darker though. not my idea , very good tutorial on YouTube... Link to comment Share on other sites More sharing options...
L33 DA17ON Posted June 17, 2020 Share Posted June 17, 2020 That looks very good. I'll have to take a pic of a close up of the stuff I've done. Its got some cracks in it as well .It's done it its self, but not broken away. Its rought when I put the tamping lines in with a scraper, but I sand it down to remove the rough stuff. Link to comment Share on other sites More sharing options...
Ferret90 Posted July 18, 2020 Author Share Posted July 18, 2020 Been a long time since I last posted on here but in the meantime , I’ve got a few bits done. I bought two Backscenes before I found a decent one and mucked one up when sticking it so I’ve got another one coming but should resolve the problem I’ve decided to add a stream and a slight hill so using polystyrene as a sort of base to carve into. Trying to lay a few bits out... Link to comment Share on other sites More sharing options...
Daniele Posted July 20, 2020 Share Posted July 20, 2020 On 11/12/2018 at 8:46 PM, Ferret90 said: Thought I would do a sort of update on First yard now with the cowshed in place and some other bits and bobs...blimin' rats This all thing looks soooooo reallll, apart from them rats doing what they do wonderful.. Link to comment Share on other sites More sharing options...
