Ferret90 Posted March 19, 2019 Author Share Posted March 19, 2019 1 hour ago, alf aphid said: Ted you have a real knack on this stuff. Very nicely executed. I’m fairly sure to the untrained eye you’d think the photos are of real life I really look forward to making up a diorama, something I’ve never done. I need to move though as I don’t have enough spare rooms! I think I’d be divorced if I used the spare room! Give me a couple of years then I’ll be coming for advice!! Cheers, Alastair yes, I find it's a nice way to display models but it doesn't need to be massive. I don't have any spare rooms and mine is just on a shelf on the wall, 6ft by about 1.5ft. I've got another few shelves underneath with tractors on but it's all about maximising space. Also it's easy to get too and you don't have any areas you can't reach I do need so better lights though Link to comment Share on other sites More sharing options...
Dusty Dan Posted March 19, 2019 Share Posted March 19, 2019 Spectacular work. I am very impressed and the space saving is a great idea. Link to comment Share on other sites More sharing options...
Ferret90 Posted April 8, 2019 Author Share Posted April 8, 2019 Link to comment Share on other sites More sharing options...
weblet375 Posted April 9, 2019 Share Posted April 9, 2019 Fantastic !!!!! Link to comment Share on other sites More sharing options...
Ferret90 Posted April 9, 2019 Author Share Posted April 9, 2019 1 hour ago, weblet375 said: Fantastic !!!!! Cheers Andy Link to comment Share on other sites More sharing options...
Dusty Dan Posted April 9, 2019 Share Posted April 9, 2019 Totally awesome! Link to comment Share on other sites More sharing options...
Ferret90 Posted April 15, 2019 Author Share Posted April 15, 2019 Just finished a belt driven saw bench.It was straightforward apart from the actual saw which I had several attempts at making with no luck, but I found a 22mm Dremel cutting disk which did the trick.I need to find a better belt though as the elastic band isn't long enough Link to comment Share on other sites More sharing options...
Dusty Dan Posted April 16, 2019 Share Posted April 16, 2019 Really nice Link to comment Share on other sites More sharing options...
844john Posted April 16, 2019 Share Posted April 16, 2019 very nice Ted, the last two pictures could almost be real, looks like a working exhibit at a vintage show Link to comment Share on other sites More sharing options...
Stabliofarmer Posted April 16, 2019 Share Posted April 16, 2019 Fantastic Ted, as always the weathering is spot on! For the belt maybe an old bike inner tube cut into a strip? Link to comment Share on other sites More sharing options...
Ferret90 Posted April 16, 2019 Author Share Posted April 16, 2019 4 hours ago, Dusty Dan said: Really nice Cheers corky Link to comment Share on other sites More sharing options...
Ferret90 Posted April 16, 2019 Author Share Posted April 16, 2019 3 hours ago, 844john said: very nice Ted, the last two pictures could almost be real, looks like a working exhibit at a vintage show Thanks John, yes it just needs a cordon around it Link to comment Share on other sites More sharing options...
Ferret90 Posted April 16, 2019 Author Share Posted April 16, 2019 16 minutes ago, Stabliofarmer said: Fantastic Ted, as always the weathering is spot on! For the belt maybe an old bike inner tube cut into a strip? Cheers James, brilliant idea, I will try that Link to comment Share on other sites More sharing options...
justy 46 Posted April 18, 2019 Share Posted April 18, 2019 Cracking stuff.. Great craftsmanship.. Link to comment Share on other sites More sharing options...
Ferret90 Posted April 18, 2019 Author Share Posted April 18, 2019 1 hour ago, justy 46 said: Cracking stuff.. Great craftsmanship.. Cheers Justin Link to comment Share on other sites More sharing options...
alf aphid Posted April 20, 2019 Share Posted April 20, 2019 I love that. So much character! Link to comment Share on other sites More sharing options...
Ferret90 Posted June 5, 2019 Author Share Posted June 5, 2019 Having a go at making another house. Each attempt gets a bit better, so ready for mod roc next, done the end wall with stone as well Link to comment Share on other sites More sharing options...
fordmajor Posted June 5, 2019 Share Posted June 5, 2019 Looking good. As usual . Are you using Balsa? Link to comment Share on other sites More sharing options...
fordmajor Posted June 5, 2019 Share Posted June 5, 2019 Sorry should have looking great [ as usual ] ie your high standard of work Link to comment Share on other sites More sharing options...
Ferret90 Posted June 5, 2019 Author Share Posted June 5, 2019 37 minutes ago, fordmajor said: Looking good. As usual . Are you using Balsa? Haha, no I'm using ply wood, I usually use cardboard but it tends to be abit weak. The problem is the windows but I found a dremel did the trick and its glued together Link to comment Share on other sites More sharing options...
F8N Posted June 5, 2019 Share Posted June 5, 2019 That's a credit to you... Lots for words really. Link to comment Share on other sites More sharing options...
Tractorman810 Posted June 6, 2019 Share Posted June 6, 2019 Its Never easy to do houses , the older ones your making ,like mine, were always so much smaller in doors and windows etc, floor levels etc , so it throws your eye out when you do it, always look to small compared to the window or door inFront of you ,puts doubt in your mind that you have it right Link to comment Share on other sites More sharing options...
Ferret90 Posted June 6, 2019 Author Share Posted June 6, 2019 4 hours ago, Tractorman810 said: Its Never easy to do houses , the older ones your making ,like mine, were always so much smaller in doors and windows etc, floor levels etc , so it throws your eye out when you do it, always look to small compared to the window or door inFront of you ,puts doubt in your mind that you have it right I've had that problem, taken me ages to get them positioned right and the right sizes. Thinking of going for cased windows as well Link to comment Share on other sites More sharing options...
Ferret90 Posted June 7, 2019 Author Share Posted June 7, 2019 Link to comment Share on other sites More sharing options...
Awdmac Posted June 8, 2019 Share Posted June 8, 2019 Your farm is a pleasure to look at, used to come across similar when I was on the rural post. Makes me think I'd better go and tidy the yard here! Link to comment Share on other sites More sharing options...
