Assorted weight blocks
Done a bit of work on cad over the weekend and drew up a few weight block designs. So far I have, cherry products smartbox, agriweld standard box, Philip Watkins x2 one with a front lid and one without.
hopefully I’ll be fit to cast them after 3d printing
20 hours ago, bluegreen said:
They look good hugh.  What I find with existing offerings is that they are only really suitable for the bigger 250hp+ machines.  Whats needed is one that fits proportionately well on the 140-180hp class machines that are most common.
Have you any suggestions of a style/type of weight block to sit in the 150hp bracket?
A mate of mine with his tailor made toolbox colour coded for his 165hp New Holland T7.210 is a good example Hugh.   The toolboxes width ,height and depth in relation to a very popular tractor in The 150-180 HP class is the key more than the curvy styling. Actually its similar in style to your 4th model image in red.   You could easily set the measurements against a Universal Hobbies NH T7 model.
16 hours ago, Stabliofarmer said:
They look very good Hugh, who did you use for the printing? Was it shapeways? and what style of printing is it?
I use 3d print uk, as it’s pa2000 nylon printed using an sls system
The weights came out well,  what were they like for getting the parts turned round and back to you? Printing is definitely the way to go for prototyping, did you consider resin printing? Pretty much flawless prints and the detail you can add in is madness
  • 7 months later...
  • 4 months later...
