Massey 550 parts 1/32
Hi,
I'm thinking of trying to build a 550 so looking at a Britains 135 chassis and a cab and bonnet from the 595. But, before I jump in and start cutting things about, does anyone know of a source of parts for this type of conversion or better still a ready built model?
Thanks.
14 answers to this question
i have done two in the past,ones a britains 135 base with repo britains parts cut down,and a old 135 loader fitted as well. that must have been 20 odd years ago, the other is al uh parts based, and is near on done bar decals, but i have not got round to finishing it yet ,cant find a pic of the old one, but here is the uh one with one of her bigger brothers .
  • Like 2
Very nice, way beyond what I had in mind!
Did you stretch the 135 chassis the 8 scale inches (6mm) as per the 148 or is it not noticeable?
didnt bother extending for this one,  doesnt really notice in all honestly, i know its not right, but the agro cutting extending and rejoining the chassis(done it twice now for my 575’s both 2wd,just isnt worth it ,took ages to get them strong enough to add the loader ect to them.this 550 may yet get a loader to make it a replacement for the current small unit 135 i have on the layout .
Posted (edited)
Apart from adding glazing to a Unimog (fiddly but the effect is worth it), I've not tried modifying anything. I have a 135, 595, and 362 as part of the collection, so just looking at possibilities for somewhere to start I'm thinking a 135 chassis with a glazed 595 cab / platform, and a 362 bonnet. Probably be a long time before it happens as a lot of time is being wasted playing with a full scale version. 😊
Edited by Hair Bear
  • Like 3
55 minutes ago, Hair Bear said:
I'd like to see it but don't go out of your way to get it.
i have to put the cases away still so i am sure i will get agro within a few days from das boss 😂😂😂😂😂
  • Haha 1
here you go, not great pics but can get better if reauired  , was way to hot up there . looks like i did it on a britains 362 chassis, jd4020 front axel with altered skinny wheels. old 6140 rear hubs  sanded down to take ford old 5000 or chaffer sprayer rear tyres and the push pin axel centre. old 135 loader arms and bucket altered to a custom frame ,and repo britains bonnet cab and arches altered to fit.got to be 20 years old i recon
  • Like 5
Hmm... I think at 20 years old it's time you moved it on?😉 Even just glazing the cab makes a difference.
Thanks for sharing.
I have a full crate of britains based mf’s i did back then , 2640’s 575’s all sorts , good few 3000 series on uh chassis and resin cabs i made my self at the time , the 3125 still appears at times in the layout . Mf200 trailers forage harvesters , mowers the list is long 😄😄😄😄
  • Like 2
Wouldn’t mind seeing these Sean if you were able to 👍 sounds interesting
3 minutes ago, Hair Bear said:
I see UH do a 148, so if they have the chassis... might have to wait and see.
i highly suspect its the same as the 135 they did, bar the decals and the roll bars / euro siroco cabs  they didnt  do to much more to it from memory
Just glanced over the shelf with the Britains 595 on it, and sat next to my 1/24 Touran and 1/25 P38 got me wondering...
Dived into the Massey handbook then using a scale converter discovered the 595 makes a very close match to a 550 - in 1/28! So close.
I'll have to get a photo of them together in 1/1 and compare.
