volvo bulker & scania artic tipper ,(reposted )
Ah, so you do have a sealed compartment then which forms part of the vacuum system??
I have three vacuum units which are fitted with Holmes blowers, one man can move 100 tons of foundry sand or similar material in a shift no problem provided he has a constant supply of skips to fill, very satisfying job!
the vac box cab be sealed yes , but there is a hydraulic door to seal off the compartments as it would try sucking the feed from the compartment you're trying to fill !
heres they type of unit that is hooked to the rear of some bulkers , although not quite as ungainly as these, they are lifted onto the brackets by forklift & there is no need for the cyclone arm as it would be piped straight to the compartment
http://www.kongskilde.com/Grain/Products/Conveying+Equipment/Tractor+powered+suction+blower+type+SupraVac+2000+%28trailer+mounted%29.htm
have you got any pics jas , it would be interesting to see. what happens to the foundry sand ?is this the sand they use for holding the moulds ? only worked in a foundry for a month or so as a fettler , dirty ,horrible job  :(
Christ I thought you said something entirely different then . . .  :-[:D
