james f Posted March 10, 2008 Share Posted March 10, 2008 I just want to say that my brother bought a Powerfarm TW off ebay that was seized as well, I sent him a link to this page and he said he tried the tips on here and it worked a treat! Quote Link to comment Share on other sites More sharing options...
MJB1 Posted March 11, 2008 Share Posted March 11, 2008 Ok ,so we're all agreed that if the TW or COUNTY stops running , the chances are pliers on the shaft is a way of solving it . what if the jag is seized ? any quick fix for that one anybody ? Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 11, 2008 Share Posted March 11, 2008 Ok ,so we're all agreed that if the TW or COUNTY stops running , the chances are pliers on the shaft is a way of solving it . what if the jag is seized ? any quick fix for that one anybody ? little harder, ,you'll need to pop it apart, i had to with mine and the tr96 to, easy enough to do mind, both my motors ran it was actually the contacts from the motor to the leads that didnt touch, so i wedged a bit of copper between each as they are very fine and they now work Quote Link to comment Share on other sites More sharing options...
Marmitemania Posted March 11, 2008 Share Posted March 11, 2008 Im sure the same fix that I posted earlier in the topic would work on the combine and forager, simply spray WD 40 on to the motor throught a hole somewhere, and put the thing in drive with the power on and then turn the driven wheels this should release the motor. It works on the tractor, but neither my combine or forager have stopped working, so I havent had to do it to those. Quote Link to comment Share on other sites More sharing options...
fordson major Posted March 12, 2008 Share Posted March 12, 2008 You guys have all been lucky with these power farms and the pto/pliers and wd40 trick I have 2 tw's and a county I had to split them all as the contacts on the motors had corroded and this was the only option They now all work. I did learn one thing from this though, If you have a mint boxed power farm TW 35 that does not work leave it well alone as my cab cracked and ruined the value of my model by about 40 pounds and putting a repro cab on will spoil it even more. :'( Quote Link to comment Share on other sites More sharing options...
lupuscow Posted March 21, 2008 Share Posted March 21, 2008 ;D ;D ;D ;D Im new to this place just read thread, confiscated the tw of my son sprayed wd40 in it and shes a runner ,yipee he aint getting it back now ,seams to have chewed the cog on the back axle though is this worth trying to fix or is it best left alone thanks. Quote Link to comment Share on other sites More sharing options...
ford 8830 Posted March 21, 2008 Share Posted March 21, 2008 straight forward to replace. Local model shop to me had the cogs on the shelf. Worth doing :D Quote Link to comment Share on other sites More sharing options...
FordTractorCrazy Posted April 16, 2008 Share Posted April 16, 2008 I just wanted to say THANKS i have the county 1884, TW35 and a powerfarm combine that hasnt run for a decade.. sure will try this and hopefully succeed.. Quote Link to comment Share on other sites More sharing options...
justy 46 Posted September 24, 2012 Share Posted September 24, 2012 Thanks to this topic,my PF TW-35 is flying up & down the floor!!! Fantastic. Quote Link to comment Share on other sites More sharing options...
kavman Posted April 4, 2022 Share Posted April 4, 2022 Hi does anyone know how to get power farm forage harvester working? Quote Link to comment Share on other sites More sharing options...
