case 1455 conversions
they dont look the same as manu kits the XL cabs look lower than they should
but thats going by what I have seen so maybee the photos
dont do the models justice and ive never seen them in the flesh :'( :'(
so I cant realy comment
F-P bought one i think & he said they where very good
i thought the cab was a bit short, but my mate said its the ertl one that is wrong! . my mate who is a IH/ case nut job, said when you look at the front it should go in at the top and bottom of the cab. he has chopped and reshaped his cabs so they look right. at this moment he is converting mr fords db 990 so the wheels turn. like i said he is a nutter. evern you got one and used a ertl cab on it could be a option i surrpose
I would say the ERTL one (XL) is too square at the front
& it is ment to be "egg shaped" like porshes desighn
but hey beggers cant be choosers thats why i liked manuel kits the
cab was bob on you couldent fault it in anyway
[at this moment he is converting mr fords db 990 so the wheels turn/i]
wots he trying to do just make a 990 with realistic steering or a conversion of another sort
the ERTL IH 784 cabs look OK
but why did they leave the bottom half of the doors on the
chassis cast  :'( otherwize they would be almost faultless
the JD 3140 (secura cab)looks ok  but the SG2 looks awfull
i must say the rear pillars slant on the model and in real life the
rear pillars are 90 degrees (square)almost but thats down to
casting purposes i recon ;) ;) ;)
I hope manuelle does start the IH 1455xl kits off again
as i would buy one off him  :'(
ertl cabs have always been a bit off.  the cabs on the JD narrow front wheel tractor (JD 4240 conversions) have the rear pillars at 90 degrees have made mine 90's
I suppose its all down to casting them and if thats the only way at the time
you cant realy blame them  :'(
i think if they made all the classics today (like the ford 5000 and 7000)
they would represent allot better all down to tecnoligy i suppose  :)
 Share
