Jez Posted March 20, 2008 Report Share Posted March 20, 2008 Ok I thought as we all have that the Norscott pick up is too wide so I will run through here how I have converted it to be a PU 300, the 3 mtr version we see in the uk. I started by taking the whole thing apart and deciding how much needed to come off each side to make it 3 mtr, 9.3 cm in 1/32 scale. I have tried to show how much needs to come off in the pictures. I measured from the middle to the outsides where the sides needed moving to. The outside parts are 1.5cm wide and the centre part that I left was 6 cm wide, 6 + 1.5 + 1.5 = 9 cm wide as a base. I did the same with the bottom part that hols the pick up in place. Quote Link to comment Share on other sites More sharing options...
Jez Posted March 20, 2008 Author Report Share Posted March 20, 2008 Here is how much i cut out of the middle of the pick up reel then re mounted and braced it back onto the bottom section. I also braced the rear of the pick up that will be used for park stands. After I had done the same adjustments with the top part and braced them back together I needed to shorten the auger. Depending on how the two parts go back together will depend on how much needs to come off the auger. I needed to glue the auger back into place when done to help strengthen the whole top part. Unfortunately the top screw holes did not quite line up so it is glued back together. it is just as strong now and I just need a forager to put it on. Here is a pic of the nearly finnished article: Quote Link to comment Share on other sites More sharing options...
Jez Posted March 20, 2008 Author Report Share Posted March 20, 2008 All that is left to do is to mount the screen back on the top and possibly take the pick up wheels off and make them moveable so they will swing around in front like the real one. Hopefully this has been some help, possibly not but it gvies you an idea of how to do it. Took me about 2 hours to to. Quote Link to comment Share on other sites More sharing options...
Deere-est Posted March 20, 2008 Report Share Posted March 20, 2008 I got a forager you can put it on It looks good Jez, PDC does PU300 stickers if your interested?? Be nice to do that on an 840 Jag, from a Norscott 880. Add two blue additive barrels and that's the chopper I'll be hauling from this year. Helpful Topic bud. Quote Link to comment Share on other sites More sharing options...
Jez Posted March 20, 2008 Author Report Share Posted March 20, 2008 I got a forager you can put it on It looks good Jez, PDC does PU300 stickers if your interested?? Be nice to do that on an 840 Jag, from a Norscott 880. Add two blue additive barrels and that's the chopper I'll be hauling from this year. Helpful Topic bud. Thanks mate, I;ve got some decal on it. I bought it off ebay as a PU300 but was still the 380 width. Cheers. I might consider doing another if anyone requests... ;) Quote Link to comment Share on other sites More sharing options...
Murray Posted March 20, 2008 Report Share Posted March 20, 2008 nice one Quote Link to comment Share on other sites More sharing options...
griffithsbros Posted March 20, 2008 Report Share Posted March 20, 2008 you might want to shorten this bit too jez ;) Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 20, 2008 Report Share Posted March 20, 2008 thats very clever jez, if i ever decide to unbox mine or get another i think i will try that out Quote Link to comment Share on other sites More sharing options...
Murray Posted March 20, 2008 Report Share Posted March 20, 2008 you might want to shorten this bit too jez ;) i would leave it as it is Quote Link to comment Share on other sites More sharing options...
Jez Posted March 20, 2008 Author Report Share Posted March 20, 2008 i would leave it as it is I'm not sure, it won't be easy to shorten it seeing as it's kind of mesh. Thanks guys, all comments appreciated. ;) Got to get me a 960 ;D ;D Quote Link to comment Share on other sites More sharing options...
rabh7840 Posted March 20, 2008 Report Share Posted March 20, 2008 i did the same with mine its a good job Quote Link to comment Share on other sites More sharing options...
Deerepower Posted March 20, 2008 Report Share Posted March 20, 2008 nicely done Jez cant wait to see it fitted on the forage harvester Quote Link to comment Share on other sites More sharing options...
Jez Posted March 20, 2008 Author Report Share Posted March 20, 2008 nicely done Jez cant wait to see it fitted on the forage harvester Me either Mark, will ahev one soon [ i did the same with mine its a good job Any pics? Quote Link to comment Share on other sites More sharing options...
HenryMC Posted March 20, 2008 Report Share Posted March 20, 2008 looking good mate was it quite easy or hard ??? Quote Link to comment Share on other sites More sharing options...
Deere-est Posted March 20, 2008 Report Share Posted March 20, 2008 I'm not sure, it won't be easy to shorten it seeing as it's kind of mesh. You'd be just aswell to make a new one Jez if your going too at all Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 20, 2008 Report Share Posted March 20, 2008 You'd be just aswell to make a new one Jez if your going too at all would say the same tris, make a frame from plastic and fill with a proper mesh??? Quote Link to comment Share on other sites More sharing options...
griffithsbros Posted March 20, 2008 Report Share Posted March 20, 2008 i am just waiting for glue to dry on mine before i put the auger etc on for the mesh bit im goin to paint the one from the siku jd grass head in claas green and use that Quote Link to comment Share on other sites More sharing options...
FB Posted March 20, 2008 Report Share Posted March 20, 2008 nice work Jez!, i was looking at the headers in the dealers the other day but they had no foragers out on display and strangely no one around to ask :o Quote Link to comment Share on other sites More sharing options...
Jez Posted March 21, 2008 Author Report Share Posted March 21, 2008 Thanks again for all the comments guys. So what do you think? Quote Link to comment Share on other sites More sharing options...
jcb4cxkid Posted March 21, 2008 Report Share Posted March 21, 2008 it looks just right Quote Link to comment Share on other sites More sharing options...
HenryMC Posted March 21, 2008 Report Share Posted March 21, 2008 very nice ;) Quote Link to comment Share on other sites More sharing options...
Jez Posted March 21, 2008 Author Report Share Posted March 21, 2008 Cheers Will ;) Quote Link to comment Share on other sites More sharing options...
Jez Posted March 21, 2008 Author Report Share Posted March 21, 2008 very nice ;) Thanks Henry, Hopefully, Possibly today i might get myself a 960 [ :-X ;) 8) Quote Link to comment Share on other sites More sharing options...
HenryMC Posted March 21, 2008 Report Share Posted March 21, 2008 Thanks Henry, Hopefully, Possibly today i might get myself a 960 [ :-X ;) 8) i would if i was you ;D Quote Link to comment Share on other sites More sharing options...
Jez Posted March 21, 2008 Author Report Share Posted March 21, 2008 i would if i was you ;D I will, so who's the dog? Quote Link to comment Share on other sites More sharing options...
