nashmach Posted April 14, 2009 Share Posted April 14, 2009 If anyone can help I'm sure someone will on there as I know there is a user on there having really big trouble with a new Manitou There is a few I think Gav - I'm sure Grumpy will sort it out for you Murray :D Quote Link to comment Share on other sites More sharing options...
Simon Posted April 14, 2009 Share Posted April 14, 2009 Does it always split the rams on the same side Murray, ie always dump or always the lift side...? It's not something daft like small bore hose fitted on one side of the circuit, restricting the return...? just a thought... \ Quote Link to comment Share on other sites More sharing options...
Murray Posted April 14, 2009 Author Share Posted April 14, 2009 Does it always split the rams on the same side Murray, ie always dump or always the lift side...? It's not something daft like small bore hose fitted on one side of the circuit, restricting the return...? just a thought... \ it just puts a tiny hairline crack in the ram \, think i will try what Grumpy said on the other forum screw the alan key out a bit see how that goes Quote Link to comment Share on other sites More sharing options...
nashmach Posted April 15, 2009 Share Posted April 15, 2009 I wouldn't believe everything Grumpy says :D Quote Link to comment Share on other sites More sharing options...
Murray Posted April 15, 2009 Author Share Posted April 15, 2009 I wouldn't believe everything Grumpy says :D Neither would i but its worth a try i suppose Quote Link to comment Share on other sites More sharing options...
rich.new holland Posted April 16, 2009 Share Posted April 16, 2009 are you goin to screw out the relief valve ?? Quote Link to comment Share on other sites More sharing options...
Murray Posted April 16, 2009 Author Share Posted April 16, 2009 might try it yet Quote Link to comment Share on other sites More sharing options...
