jcb4cxkid Posted August 10, 2008 Posted August 10, 2008 you will need a small philps screwdriver step: 1 pick up your claas and remove the cab just to save it getting broken step: 2 turn it over you will now see 4 screws unscrew them(they might be tight) Quote
jcb4cxkid Posted August 10, 2008 Author Posted August 10, 2008 step: 3 now the loader should wobble about take the floor plan away might need a bit of help to come away it should look like this step: 4 undo the 3 screws on the front but dont take one out at a time do it in stages so they all come out at the same time (see the diagram below) Quote
jcb4cxkid Posted August 10, 2008 Author Posted August 10, 2008 step: 5 take away the bit you just unscrewed and the loader should just fall off step: 6 put it all back together whitout the loader just do all that backwards if you whant to fit a loader thanks for looking hope thats helped Quote
jcb4cxkid
step: 1
step: 2
2 answers to this question
