andrewstanford Posted September 13, 2008 Share Posted September 13, 2008 iwas wondering wat should hapen when i charge my battery the red light stays on all the time any help Quote Link to comment Share on other sites More sharing options...
FB Posted September 13, 2008 Share Posted September 13, 2008 iwas wondering wat should hapen when i charge my battery the red light stays on all the time any help put battery in charger turn on mains SWITCH on battery, light should flash green Once charged, light will stay green try this a few times as they can be tempremental at times if this doesnt work after a few times, take it back as its a dodgy charger Quote Link to comment Share on other sites More sharing options...
andrewstanford Posted September 13, 2008 Author Share Posted September 13, 2008 i found out it is the battery tht isn't working so i am sending it back to farmmodels and they are sending me another Quote Link to comment Share on other sites More sharing options...
powerrabbit Posted September 13, 2008 Share Posted September 13, 2008 I think that I read somewhere that if at first charge the red light stays on, remove from charger and put in charger again and switch on. I thought that I had a problem with the handset on mine but found that you have to use the alkaline 1.5 volt batteries in it and not re-chargable ones as the latter are only 1.2 volt and won't work the tractor. Quote Link to comment Share on other sites More sharing options...
