Simon Posted May 5, 2009 Author Share Posted May 5, 2009 Thanks guys... Henri Walker did the decals for it Fred Quote Link to comment Share on other sites More sharing options...
smallclaas Posted May 5, 2009 Share Posted May 5, 2009 Lovely stuff Simon, that Reanu' has really turned out well, true craftsmanship Quote Link to comment Share on other sites More sharing options...
nhts115 Posted May 11, 2009 Share Posted May 11, 2009 good attempt but it looks more like a 103 than a 106. bonnet and wheel base don,t just look long enough for 6 cylinder Quote Link to comment Share on other sites More sharing options...
tractorbob Posted May 11, 2009 Share Posted May 11, 2009 fair play ,lot of work gone in to that ..dont know much about renaullts ,but after seeing this one Quote Link to comment Share on other sites More sharing options...
colin Posted May 11, 2009 Share Posted May 11, 2009 good attempt but it looks more like a 103 than a 106. bonnet and wheel base don,t just look long enough for 6 cylinder you musten know much about Renaults then because the model is 10mm longer than the 103 britains made Quote Link to comment Share on other sites More sharing options...
Simon Posted May 12, 2009 Author Share Posted May 12, 2009 you musten know much about Renaults then because the model is 10mm longer than the 103 britains made I keep thinking that but it tallies with the dimensions we took.... the conclusion I came to was that the Britains floorpan and cab might be a fraction over scale and the original bonnet a little bit under, making it seem a bit top heavy Thanks Rob & Garrett I put a lot of work in that's for sure... \ I thought it was a 'good attempt' Quote Link to comment Share on other sites More sharing options...
Eurodeere Posted May 12, 2009 Share Posted May 12, 2009 The 106 was 25 cm longer than the 103 and the wheel base 26 cm more. That comes out at approx 8 mm in 1/32 scale, I think that means they look similar. Quote Link to comment Share on other sites More sharing options...
colin Posted May 12, 2009 Share Posted May 12, 2009 The 106 was 25 cm longer than the 103 and the wheel base 26 cm more. That comes out at approx 8 mm in 1/32 scale, I think that means they look similar. yeah thats wot i ment......simon has the model spot on Quote Link to comment Share on other sites More sharing options...
Simon Posted May 13, 2009 Author Share Posted May 13, 2009 She certainly looks about right in your avatar Col that's for sure It was only about 8mm longer [might even have rounded it off to 10 \ ] The 106 does look a lot more rangey than the 103 in real life, the model has come out 'stockier' than I was expecting but as I say, it did stack up with the dimensions off Colin's machine Quote Link to comment Share on other sites More sharing options...
