marstons silage trailer
British is the best  (JCB)
11 answers to this question
twist oppostie directions, if that fails remove the tyres, (they do come off without the hot water method suggested above just a little harder to do), then twist again but with a one wheel hub in a vice the other in a pair  of pliers , or plumbers pliers, as they grip better, might rough the tyre ridge up, but that wont matter as once the tyres are back on job done, if you aint got a vice use 2 sets of pliers,
sometimes the wheel hub center hole is a bit to small for the knureld end of the axel so they won't budge like that,
