Paul Palmer Posted June 24, 2010 Share Posted June 24, 2010 how do you get the floorpans off the case ih maxxum and the case ih puma cvx 225 thanks in advance paul Quote Link to comment Share on other sites More sharing options...
Fenside MF Posted June 24, 2010 Share Posted June 24, 2010 Hi Paul, maxxum is clipped really tight in to the chassis at back(just in front of rear linkage) and I think in to the bonnet/engine section too,get the wheels off first ,I found the best way was to run a junior hacksaw blade between the foorpan and chassis so you end up cutting the cips off as you won't need them if for a convo,and then saw down between dashboard and engine to cut the front one. I took apart the t7060 but the puma should be the same,get the wheels off then you will see its held on by a rivet at the back,all I did was drill the head of the rivet out and job done I think on that. Quote Link to comment Share on other sites More sharing options...
Paul Palmer
paul
1 answer to this question
