Front weight blocks
Hicksy
Hi Phillip clinks the links I have added for a browse,some are casted from resin or white metal so you might need to drill 3 holes so it fits in the arms and toplink,others there are off weise uh models etc
http://www.farmmodels.nl/Webwinkel-Category-204290/Parts.html
http://farmmodelspares.co.uk/epages/www_farmmodelspares_co_uk.sf/en_GB/?ViewAction=View&ObjectID=1219556
http://www.artisan32.com/category.php?id_category=12
http://www.britainstoyfarm.net/90275/info.php?p=3&cat=284725
The genuine paint for those two uh would be mf 50th grey although uh paint may be slightly different shade,I think I have some revell or humbrol paint which is very close so could give you the paint number if you need it,hope that helps a bit.
Thanks for your help Jamie
Phil
I bought a PDC weight block for my 7624 but when I fitted it to the tractor it just looked way to big!! I reckon a real size verson of it would be 1500kg which is unrealistic. ............so im in the market for a less crude more accurate block and thanks to fenside ive just spotted the classly looking black one on the Farmmodel site :)  Obviously it will need painting grey.
If you look at the weight block on the 6475 model ,that is correct sizewise....................however its only the rear part of the double weight used on the 7600s but it does give a accurate scale of whats needed.
