bigbear Posted September 8, 2013 Share Posted September 8, 2013 After being a devoted Britains man for years, I've recently bought a number of vintage, but still new-in-box Siku tractors. They are great, except that the wire that runs from the base of the steering column to the front axle is sort of 'bubbled' where it has rested near, or on, the painted axle. I thought it was just a one off, but ALL of the old Sikus I bought are the same. It's only a minor problem, but is there a good way to fix this, please? I thought I might give it a gentle rub with some emery paper and then lay on a coat of clear varnish, but don't want to do this on all of the models... Any suggestions, please? Link to comment Share on other sites More sharing options...
0025 Posted September 10, 2013 Share Posted September 10, 2013 i use mcvities wrapers it does the tric nicely Link to comment Share on other sites More sharing options...
bigbear Posted September 11, 2013 Author Share Posted September 11, 2013 Well, that just takes the biscuit! Thanks, I'll give it a try. Any particular type of biscuit better? Link to comment Share on other sites More sharing options...
0025 Posted September 11, 2013 Share Posted September 11, 2013 yea i had some problems i belive the plastic isent strong enough what you do is where the cab sreering rod hole is just cut a small pice and put it in that hole and put the cab on. Link to comment Share on other sites More sharing options...
