hiya all, ive just started collecting 1/32 scale models and was wondering how to dismantle a siku mf on floats which i have acquired for spares / modification,any advce gratefully received.
Rik
Hi rick, what do you want off it? you need a stong mid sized flat head screw driver, prise open the clip things and it all falls appart like that, be carefull not to slip and stab your self like i have in the past, it hurts alot..
hope thats helpfull for you
Nick
thanksNick.
basically the wheels for a future project and the hitch to modify an ertl fw30 which only has a tow pin.
hopefully i wont stab meself then lmao
Rik
some siku also come apart from the underside as they are screwed together as a top and bottom half, the rear wheels and hitch are held together between them, so have a quick check first to see if this is the case,
done this model a couple of times sean,
rule of thumb is is it doenst have cab glass it isnt screwed with siku
