Replicagri Claas Disco 3500c problem?
Barry
Opened the Claas Disco and fount there was an adaptor to connect the mower to a tractor.
Found that the adaptor fitted the UH MF 7499 I have on the shelf, so went about fitting the mower to the adaptor.
Now i've looked and looked at the way it fits, but the mower will not fit onto the adaptor!
Am i missing something?
If you look at the pictures, the lower horizontal bar on the adaptor clashes with the PTO shaft on the mower, meaning the adaptor will not position onto the hooks??
  Had same problem with mine. Think I removed toplink pin, then fitted it to lower links and GENTLY eased it into place and fitted new toplink pin. Not sure if PTO went under or over but can look later. Hope this helps.
  • 5 weeks later...
