Deerepower Posted September 10, 2007 Author Share Posted September 10, 2007 Greta job Mark. I envy you fellas who can buy a model to modify without the postage doubling the total cost of the model :'( Can you explain how replacing the bottom of the original linkage has resulted in the modified version being able to hold up the heavier 3PT equipment. Or have I got it wrong and the 7000 doesn't have that problem. the 7000 comes with cr@p linkage so I cut it off and made new linkage out of the old britains linkage (this one is off a mf 2680) it has been trimed and fitted to some pastic, where the standard linkage piveted I simply drilled a hole in the plastic and used a screw to hold and tighten the linkage and it still lifts up and down also you can tow trailers and other trailered machinery with it Quote Link to comment Share on other sites More sharing options...
the other green Posted September 11, 2007 Share Posted September 11, 2007 the 7000 comes with cr@p linkage so I cut it off and made new linkage out of the old britains linkage (this one is off a mf 2680) it has been trimed and fitted to some pastic, where the standard linkage piveted I simply drilled a hole in the plastic and used a screw to hold and tighten the linkage and it still lifts up and down also you can tow trailers and other trailered machinery with it Thanks for that mate. Crystal clear now. Quote Link to comment Share on other sites More sharing options...
rich.new holland Posted September 11, 2007 Share Posted September 11, 2007 thanks mark Quote Link to comment Share on other sites More sharing options...
