Powerstarâ„¢ Posted February 19, 2008 Share Posted February 19, 2008 Sorted ;) Cheers Simon Quote Link to comment Share on other sites More sharing options...
Deerepower Posted February 19, 2008 Author Share Posted February 19, 2008 Burnt it ? ;D near enough bl00dy steps break easy on it : Quote Link to comment Share on other sites More sharing options...
SIMON. Posted February 19, 2008 Share Posted February 19, 2008 near enough bl00dy steps break easy on it : you should see a real one the door handels fall off keeps bleeping at you :'( :'( :D Quote Link to comment Share on other sites More sharing options...
Kiwi6920 Posted February 20, 2008 Share Posted February 20, 2008 you should see a real one the door handels fall off keeps bleeping at you :'( :'( :D Top plop quality those Mfs, rung the dealer up to day to get a demo one, It burnt out on the way here Did do more work for the day then the case tho Quote Link to comment Share on other sites More sharing options...
james f Posted February 20, 2008 Share Posted February 20, 2008 Definitely break it up, I got an unboxed one as a present along with the tractor that drives it (large rigid-frame Case IH four-wheel-drive) and have pulled it apart to make something better out of it. I plan to use the same chassis but with the front lopped off and the body lowered to make it more realistic, plus a new set of tipping rams. The trouble with the original tipping mechanism is that the gears inside are too fragile and tend to split and then spin on the hexagonal shafts allowing it to tip up but not down or vice-versa. In short, you did the right thing in chopping it. I like Sean's idea of doing a scratch built chassis for it because the original is not easy to work with. Quote Link to comment Share on other sites More sharing options...
Powerstarâ„¢ Posted March 4, 2008 Share Posted March 4, 2008 Is it on it's way yet Simon? Quote Link to comment Share on other sites More sharing options...
Fenside MF Posted March 7, 2008 Share Posted March 7, 2008 How is this trailer coming along mate and please could you measure the diameter of the wheels as I think I've found some similar sized siku one's for my own conversion Quote Link to comment Share on other sites More sharing options...
Deerepower Posted March 7, 2008 Author Share Posted March 7, 2008 well it's been chopped up the sides has been used for another conversion the wheels messure 25mm by 11mm if thats a help to you jamie Quote Link to comment Share on other sites More sharing options...
Fenside MF Posted March 7, 2008 Share Posted March 7, 2008 well it's been chopped up the sides has been used for another conversion the wheels messure 25mm by 11mm if thats a help to you jamie cheers mate I've just got hold of some siku one's off the flatbed trailer with ramps that are 25mm x 10mm Quote Link to comment Share on other sites More sharing options...
