Scotty12 Posted March 18, 2008 Share Posted March 18, 2008 Does anybody know how to take the cab off a UH Massey 5480 or UH Fendt 718? Thanks Scotty Quote Link to comment Share on other sites More sharing options...
TM190 Posted March 18, 2008 Share Posted March 18, 2008 Massey 5480...... Four screws, one above each set of steps and under floorplan between wheels then pull up. Quote Link to comment Share on other sites More sharing options...
Scotty12 Posted March 18, 2008 Author Share Posted March 18, 2008 Cheers TM Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted March 18, 2008 Share Posted March 18, 2008 i think the fendt is just cut the glued lugs under the rear wheel arches and it lifts of from memory, long time since i took one apart like that Quote Link to comment Share on other sites More sharing options...
Fenside MF Posted February 3, 2009 Share Posted February 3, 2009 Has anyone got any tips on removing two of the cab roof lights they seem well stuck Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 3, 2009 Share Posted February 3, 2009 drill the insdie of the cab topp out, you will see the rivets when you pop the roof lining off, then push them out, might need to drill carefully one of mine poped out, the other had tobe drilled thats for the fergy Quote Link to comment Share on other sites More sharing options...
Fenside MF Posted February 3, 2009 Share Posted February 3, 2009 Thanks for the help Sean will have to try that on another one as the one I'm working on the cab won't come off the floorpan now Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 3, 2009 Share Posted February 3, 2009 they are a metal from memory, but its quite a fine pin into the cab top, you might be able to leve rit out ,really depends on who busy the glue man wa son the line that day i recon Quote Link to comment Share on other sites More sharing options...
Scotty12
Thanks Scotty
7 answers to this question
