CJ Posted July 4, 2008 Share Posted July 4, 2008 hi i need to get a 3m front press sort of like this i know it aint a great pic but if any one has an idea please post it up thanks Quote Link to comment Share on other sites More sharing options...
denis086 Posted July 4, 2008 Share Posted July 4, 2008 that german site baerny i think does the disc thing on that if you feel up to a build Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 4, 2008 Share Posted July 4, 2008 as denis said, the actuall discs are avaiable in white metal. barneys amougst others do them not sure if henri walker might as well, front tines, mmm old britains harrow ones maybe?? bit of plastic and bobs your uncle, man of your skills should be able to knock that up in a few hrs no worrys Quote Link to comment Share on other sites More sharing options...
denis086 Posted July 4, 2008 Share Posted July 4, 2008 as denis said, the actuall discs are avaiable in white metal. barneys amougst others do them not sure if henri walker might as well, front tines, mmm old britains harrow ones maybe?? bit of plastic and bobs your uncle, man of your skills should be able to knock that up in a few hrs no worrys im sure you could make the tines yourself with a bit of plastistruct cut in to a strip and shaped using an old soldering iron the bit is gone on it then its just a matter of shaping it with a fine pliers i have one it got no teeth on it just a fine head very handy might get a pic later if you want the frame looks easy enough to me apart from the linkage cant clearly make that out might have a bit of work Quote Link to comment Share on other sites More sharing options...
CJ
3 answers to this question
