neilw Posted November 16, 2008 Share Posted November 16, 2008 How easy is it to swop the body of a siku tractor on to a UH chassis?? E.G Siku Fendt 718 on to UH Fendt 818 chassis?? Quote Link to comment Share on other sites More sharing options...
bluegreen Posted November 24, 2008 Share Posted November 24, 2008 Why bother their virtually the same size tractor? Switch the 818 decal to 718 would be quicker Quote Link to comment Share on other sites More sharing options...
neilw Posted November 25, 2008 Author Share Posted November 25, 2008 I want the 818 to have a siku hitch but cant see how to change it without the whole chassis. Unless one of you experts knows different.... Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 25, 2008 Share Posted November 25, 2008 only way to do that is cut the uh chassis off at the back and refit the siku hitch, prob not an easy job from my memorys of the uh chassis, i guess the body work off the uh might fit, along with the rear wheels, but the siku front axels totaly different, so you would need to keep the siku wheels all round, unless you fit the uh front axel to the siku chassis Quote Link to comment Share on other sites More sharing options...
neilw Posted November 25, 2008 Author Share Posted November 25, 2008 sounds like a complicated job for a novice like me, i'll have to re think my implements instead....! Quote Link to comment Share on other sites More sharing options...
Simon Posted November 25, 2008 Share Posted November 25, 2008 You can buy Siku hitches on their own, £2.50 from Farm Models one example, cut the UH one off and glue the Siku one on with some Roket.... [obviously not exactly that straightforward but that's the principal ] Better than destroying one good model surely? Presumably you want this thing to work well, hence the UH 818 hitch is going in favour of a Siku one or have you confused me /I confused myself... In one breath you seem to want Siku body onto UH chassis and in another it's Siku hitch onto UH chassis...... Quote Link to comment Share on other sites More sharing options...
neilw Posted December 6, 2008 Author Share Posted December 6, 2008 its siku hitch on to uh body, i did explore it the other way round as an option but am going to get an expert to do instead!!! Quote Link to comment Share on other sites More sharing options...
nathan Posted December 6, 2008 Share Posted December 6, 2008 if its the A frame front linkage you need, why not cut the A part from the front of the siku linkage and make it fit onto the 818 linkage if that makes any sence \ Quote Link to comment Share on other sites More sharing options...
neilw Posted December 7, 2008 Author Share Posted December 7, 2008 no, its the rear one. basiclly i want an 818 with a siku rear linkage, probably a weight on the front although open to debate on that one... Quote Link to comment Share on other sites More sharing options...
MJB1 Posted December 7, 2008 Share Posted December 7, 2008 if you got patience you can strip the UH chassis of rear linkage , & buy the siku rear linkage seperately , if i remember rightly the siku part has a lug which if you drill & file right can be fitted as well as glued to the UH chassis Quote Link to comment Share on other sites More sharing options...
neilw Posted December 7, 2008 Author Share Posted December 7, 2008 thanks for the tip - may have a crack myself... Quote Link to comment Share on other sites More sharing options...
Kiwi6920 Posted December 7, 2008 Share Posted December 7, 2008 Easyest way is strip your 818 down, remove the rear links off that, re assemble that, Take a Siku JD 74/7530, strip that down, get a hack saw and cut the linkage off the back of that, it is part of the chassis so you will get a nice big Flat mounting plate, use the glue/cement of your chooice to sitck it on the back of the 818, put a implamnet on to set the heights before you glue it in place... Hope that helps you Quote Link to comment Share on other sites More sharing options...
