MODELFARMER Posted January 1, 2011 Share Posted January 1, 2011 Hi all Yes I have something on out farm that is not Green with yellow Wheels, (And yes when I can I will fix this Grave error) Now to the point . . . The Gear box on this little lady is 1-4 + Reverse, And a High-Neutral-Low Stick on the floor between me legs ok Now the problem is thus . . . It has become recently that getting the tractor in and out of Gear is a real Pain, no crunching but just V hard to get pushed in, 2nd which is central and push stick forward is the hardest to find Do any of you have this problem? or have a solution/know what is wrong??? Ricky Quote Link to comment Share on other sites More sharing options...
tractorbob Posted January 1, 2011 Share Posted January 1, 2011 had that problem with our 4000 ..filled with gear box oil(very low) ...problem solved.have you checked yours Quote Link to comment Share on other sites More sharing options...
DBfan Posted January 1, 2011 Share Posted January 1, 2011 as said check the oil or could it maby be the clutch i will ask my dad to morow he works at tractors everyday of the year Quote Link to comment Share on other sites More sharing options...
jakescot Posted January 1, 2011 Share Posted January 1, 2011 the 390`s round here in my area , almost all of them, needed a small spring in the centre of the gearbox ,very cheap spring something like a quid or so but a big repair bill as it was a double split to get into the gearbox to replace it...might be that could even be a worn selector as I had on the 590 , I actually broke it eventually my 390 was I think near 8000 hours before it needed the spring fixed Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted January 2, 2011 Author Share Posted January 2, 2011 Hi Thanks for replies I checked the oil, its not very low but is slightly on the low side of halfway, I have topped it up to the max will be interesting to see if that sorts it, if not It may be that wee spring, brilliant, that'll be next fri and sat planned tearing her apart Quote Link to comment Share on other sites More sharing options...
roberthenning Posted January 2, 2011 Share Posted January 2, 2011 Hi all Yes I have something on out farm that is not Green with yellow Wheels, (And yes when I can I will fix this Grave error) Now to the point . . . The Gear box on this little lady is 1-4 + Reverse, And a High-Neutral-Low Stick on the floor between me legs ok Now the problem is thus . . . It has become recently that getting the tractor in and out of Gear is a real Pain, no crunching but just V hard to get pushed in, 2nd which is central and push stick forward is the hardest to find Do any of you have this problem? or have a solution/know what is wrong??? Ricky there lies your problem there,some tractors are just not as smooth as the big green machines Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted January 2, 2011 Author Share Posted January 2, 2011 : : : : : :laugh: :laugh: :laugh: :laugh: :laugh: Quote Link to comment Share on other sites More sharing options...
TM190 Posted January 2, 2011 Share Posted January 2, 2011 Did you try my plan yet? ;D Be easier than splitting her! Quote Link to comment Share on other sites More sharing options...
DBfan Posted January 2, 2011 Share Posted January 2, 2011 Did you try my plan yet? ;D Be easier than splitting her! im gessing that would be along the lines of selling her and getting something better Quote Link to comment Share on other sites More sharing options...
MODELFARMER Posted January 2, 2011 Author Share Posted January 2, 2011 im gessing that would be along the lines of selling her and getting something better No it was along the lines of box section and longer gear lever Quote Link to comment Share on other sites More sharing options...
TM190 Posted January 2, 2011 Share Posted January 2, 2011 No it was along the lines of box section and longer gear lever = more Leverage! Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted January 2, 2011 Share Posted January 2, 2011 blimey Blake if that's what college taught you god help any tractors you have to fix mate ;D Quote Link to comment Share on other sites More sharing options...
