I have recently bought an unboxed No 9580 Britain's Magirus Deutz Iveco Animal transporter. I plan to do some small changes and then "rope on" two damaged unboxed models I have.
I would like to remove the cab and the glazing and convert to right had drive and also respray the cab. What is the best way to do this ...I see there is a little black piece of the dashboard sticking through the front windscreen.
In addition I want to add rope hooks to the shims....would paper clips be the best "metal" to use for this
Finally I would like to respray the body and how easy it it to remove it from the chassis....I see there is a metal stub under the first prop shaft. Its not crucial I remove the body but it would save time masking up.
BC
4 answers to this question
