BGU Posted July 17, 2007 Share Posted July 17, 2007 I have bought a replacement exhaust and airfilter for my JD4020. But how do I get the bonnet off?? Quote Link to comment Share on other sites More sharing options...
FB Posted July 17, 2007 Share Posted July 17, 2007 serious answer.....sledge hammer, SPN has one i dont know, F-P will know! Quote Link to comment Share on other sites More sharing options...
BGU Posted July 17, 2007 Author Share Posted July 17, 2007 serious answer.....sledge hammer, SPN has one i dont know, F-P will know! I post on here for a serious answer!!! And get some Mod who just want's to increase his post count interfering!!!!! :D :D Please bring back spell check!!!! Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 I post on here for a serious answer!!! And get some Mod who just want's to increase his post count interfering!!!!! :D :D Please bring back spell check!!!! Drill the rivet-out underneath the steering block and hey presto. Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 Drill the rivet-out underneath the steering block and hey presto. Though the thing is Kev, if you only want to replace the exhaust and ir filter you're probably best just cleaning up the original holes and push-in the new parts with a bit of glue on the end, because the bonnet will always be loose unless you glue that cak on, but you'll still see the drill holes. So I'd be more inclined to leave the bonnet on. Quote Link to comment Share on other sites More sharing options...
BGU Posted July 17, 2007 Author Share Posted July 17, 2007 Drill!!!! I was hoping it would be a bit easier than that!!! How do you fix it back on again then? Just seen your other post. I will try that first!! Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 Drill!!!! I was hoping it would be a bit easier than that!!! How do you fix it back on again then? Just seen your other post. I will try that first!! I would mate......much tidier job. Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 17, 2007 Share Posted July 17, 2007 only way i know of without breaking the bonnet arround the dash area is as fw said , very fine drill pop the rivet out, and glue it back on after, i know what you mean about the air filterm, they are actually screw on from underneath, as i found out by accident, need to replace one on mine at some point Quote Link to comment Share on other sites More sharing options...
BGU Posted July 17, 2007 Author Share Posted July 17, 2007 What about the exhaust? that won't be easy to drill out as it is oval?? Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 What about the exhaust? that won't be easy to drill out as it is oval?? Don't drill it just get it clean enough to firmly push the new one in. Try filing it or just even a small screwdriver will do the trick and just get the old plastic out the way. Quote Link to comment Share on other sites More sharing options...
FB Posted July 17, 2007 Share Posted July 17, 2007 What about the exhaust? that won't be easy to drill out as it is oval?? have you now got an oval Drill ???............................ :D :D Stick to Wills idea, leave drilling as a last resort Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 17, 2007 Share Posted July 17, 2007 the exhaust is a screw fixing to i think from underneath kev, you can get the bonnet to tip upwards if you gently prise it front the front above the metal work, but watch the dash area as you tilt it, tends to break it arround there Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 have you now got an oval Drill ???............................ :D :D Stick to Wills idea, leave drilling as a last resort Square one's are far more effective Ben. : Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 the exhaust is a screw fixing to i think from underneath kev, you can get the bonnet to tip upwards if you gently prise it front the front above the metal work, but watch the dash area as you tilt it, tends to break it arround there Yeah try that and if you do break it I'll send you another as I have two of them which are of no use to me. Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 17, 2007 Share Posted July 17, 2007 just 2 oh deere i have about 8 lying arround all no good, the air filters fell of but the exhausts are still in place Quote Link to comment Share on other sites More sharing options...
FW Posted July 17, 2007 Share Posted July 17, 2007 just 2 oh deere i have about 8 lying arround all no good, the air filters fell of but the exhausts are still in place Air filters and exhausts I keep, but that's it. Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted July 17, 2007 Share Posted July 17, 2007 when i say fell off, more liek the scappel assisted :D Quote Link to comment Share on other sites More sharing options...
BGU Posted July 18, 2007 Author Share Posted July 18, 2007 Before... Hole drilled out Quote Link to comment Share on other sites More sharing options...
BGU Posted July 18, 2007 Author Share Posted July 18, 2007 After. Didn't have the balls to try the exhaust! Still got the repaired one on! :D Better?? Quote Link to comment Share on other sites More sharing options...
BGU Posted July 19, 2007 Author Share Posted July 19, 2007 Just looked at a catalogue and the exhaust I have is for the 4wd version. It should be black on this one. Quote Link to comment Share on other sites More sharing options...
BGU
19 answers to this question
