B O R Posted February 11, 2011 Author Share Posted February 11, 2011 6480,much better now on the correct coloured rims Link to comment Share on other sites More sharing options...
B O R Posted February 11, 2011 Author Share Posted February 11, 2011 one more of the new 6480.....the 6480 is one of MF,s best sellers.....ive 2 more lovely MF,s almost ready at minute,involving lots more work then this one.....just awaiting some small parts at minute to complete them Link to comment Share on other sites More sharing options...
B O R Posted February 11, 2011 Author Share Posted February 11, 2011 its annoying that the 6475 comes on wrong colour wheels,loader brackets and no loader and a blank glass for the right door...id like to take another while at this tractor and see if i can remove the cab,fit a driver,add right side hand rails and door handle to finish it off...... Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 11, 2011 Share Posted February 11, 2011 another nice bit of work bor,and one convo that is quite easy,only question i have ,is how do you remove the 6475 decals? Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 11, 2011 Share Posted February 11, 2011 at a guess, it would be nail polish remover, carefully applied with a cotton wool bud, just rubs of then paul, trick is not to go to heavey so you also remove the red paint Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 11, 2011 Share Posted February 11, 2011 at a guess, it would be nail polish remover, carefully applied with a cotton wool bud, just rubs of then paul, trick is not to go to heavey so you also remove the red paint i have heard of that method sean,i would s**t myself that i would take off the colour underneath the decal Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 11, 2011 Share Posted February 11, 2011 pdc did a bit in model farmer on it ,its easy enough to do, had done it several times myself ,just need to be light fingered so to speak, something i aint Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 11, 2011 Share Posted February 11, 2011 pdc did a bit in model farmer on it ,its easy enough to do, had done it several times myself ,just need to be light fingered so to speak, something i aint thats me out then Link to comment Share on other sites More sharing options...
B O R Posted February 12, 2011 Author Share Posted February 12, 2011 paul,i didnt remove the 6475 decal..i had the 6480 decal made at exactly the same size and got it done on a red background and fixed it over the existing 6475 decal,easy job Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 12, 2011 Share Posted February 12, 2011 paul,i didnt remove the 6475 decal..i had the 6480 decal made at exactly the same size and got it done on a red background and fixed it over the existing 6475 decal,easy job thanks bor,did you do the decals,or somebody else? Link to comment Share on other sites More sharing options...
masseyjack590 Posted February 12, 2011 Share Posted February 12, 2011 i've just finished one these i put the floorpan and cab off 5480 on it because i couldn't get the cab off the 6475 on to the 5480 floorpan it looks good now yours looks good with the correct colour wheels Link to comment Share on other sites More sharing options...
Tommy Gough Posted February 12, 2011 Share Posted February 12, 2011 Looks better now, i must say. Is it easy to take the loader brackets off as i want to attempt it? Link to comment Share on other sites More sharing options...
B O R Posted February 12, 2011 Author Share Posted February 12, 2011 my 6480 decals came from henri walker.....the loader brackets were easy to remove yes..just screw out the 2 screws and then there is a small piece to cut that joins them to the inner step,a snip with a blade between the joint does it discreetly....i may actually fit a 5480 cab and floorpan as i have a spare here,itd be an easy way to go to get it looking perfect Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 just finished this project for a friend....1200 forestry... changed the wheels,added a grab from a britains valtra and modified it,modified the grab,added a modified jcb 4cx front blade,made the rams and brackets,made the brass gaurds and added mesh,removed linkage,moved rear lights to top of cab,shortened air breather,added driver and levers and turned seat around,added hoses to the grab and crane,modified rear diesel tank on inside,think thats it Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 levers fitted to cab Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 crane and blade fully operational Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 1200 Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 1200.air breather was shortened as requested Link to comment Share on other sites More sharing options...
B O R Posted February 13, 2011 Author Share Posted February 13, 2011 last 2 pics....i have a very special mf tractor almost finished for myself...more on this soon Link to comment Share on other sites More sharing options...
B O R Posted February 25, 2011 Author Share Posted February 25, 2011 ive had these awaiting decals now for the last 4 weeks...i wanted a howard 90" or 80" so made 4..2x 80" and 2x90"....these were requested by good customers a long time ago and wouldnt be a thing id do more of....i counted 28 individual parts i had to make for each model in the build.... Link to comment Share on other sites More sharing options...
B O R Posted February 25, 2011 Author Share Posted February 25, 2011 howards.all HR40 machines,that is the heavier duty model Link to comment Share on other sites More sharing options...
B O R Posted February 25, 2011 Author Share Posted February 25, 2011 howard Link to comment Share on other sites More sharing options...
B O R Posted February 25, 2011 Author Share Posted February 25, 2011 hr40 Link to comment Share on other sites More sharing options...
