Hollytree farm/contracts
  • Replies 409
That's a lovely bale grab you have made, Brian. When you say 'tightened up the rams'; how did you do that? I've a model or two which could do with that attention. 8240 isn't too bad either. I do like the slurry gear though 8)
well Deerest,its not easy,if possible my 1st option is to remove the ram sleeve,and make a new one from brass with soldered eye on...but if the existind ram is the wrong diameter and you cant get brass to fit,the other way is to remove the ram sleeve and coat it in a good super glue,let the glue run down it,turning it around until even,then let sit for a hour,then repeat as necessary,its slow but very effective and id reccommend not refitting the sleeve to the ram for at least half a day
  • 5 months later...
  • 5 months later...
