Massey Conversion
moogie
If i were to make a Massey Ferguson 595 4X4 what would be the best and easiest front axle to use?
The Fiat DT 880 front wheels are about the correct size, would this axle work? I would like the steering to still work than to be fixed.
Thanks, Noel.
Thanks, Noel.
you could use them or the britains deutz 110,any britains with this size gets used alot
i have a feeling the pin hole on the fiats slightly different? might be deeper or shorter so the wheels either wont fit, or are slack, hence why the deutz ones uses as paul also mentioned, i have a fiat one and a mf chassis i nthe shed so can try for you before you pull anything apart if needed
If you wouldn't mind, that would be great.  ;)
Still have to buy a donor tractor, so it would save a bit of time and money.
Thanks.
If you read David Pullens first book on Britains tractors, it tells you which castings were used on different models and there were several that used the same casting so lend themselves to these sort of conversions. I know this is off the point a little but thought worth mentioning, especially to our younger members that may be getting interested in converting.
Younger members??  :of  I turned 41 today!  :)
:D :D  .. that's got to be one of the funniest posts I've read on here in ages  :D :D
sadly... you are younger than me as well... you whippersnapper you  :D :D :D
Hey grandpa, tell me that story again about how you had to walk three miles a day in your bare feet, just to get a loaf of bread when you were little, working down the mines pushing the carts.  :P;D
Oh oh  :of  wait till one of the Aunties get ahold of you Moogie woogie it will be off to the naughty step for you.... :-\ :D
How about an MF240 from a UH 135 skid 'Moogie Woogie Bugal Boy from Company B'  ??? (only Pops is old enough to remember that song.. sorry to anyone under the age of 85)
Martin Reeve made me an MF230 once like that.... it is suuuuuuuperb in the extreme.. I'll get some pics up tonight for inspiration if you like ?
