guys, i have hit a brick wall on the lely build, i have made the rams for the folding header, but the only way i can get them to close properly within the space i have is to make a swing arm to which they attach, this allows the end to move back,allowing the upright position , this however does block my mounting position for the reel and sails ect also on the real thing the rams stay flat when in storage or used position, the only way i can see to do it is use a multi stage ram, but i only have 1cm of lenght to play with ,my normal car areil route is way to big ,i have tried that today.i got a 2 stagemade but i do not have enough length to play with for the stops inside each section, does anyone have any idea if such a small multi stage ram is avaiable on any models?? or infact any idea how i can overcome this problem?
Tractorman810
cheers
10 answers to this question
