i started this weeks ago but only got around to finishing it tonight.
i dont know how people usually connect the two halfs of the linkage , but i have used two very small screws.
what do you think?
tidy, just nip off the rod between the two rams as its not required and you're sorted
thanks ricky , will do that today
tidy work that. take much to make it fit on the chassis?
thanks nick ,had to file down the chassis alot to get it to fit properly
tidy rich, got to be honest i used some left over small uh screws for mine on the 3125 ,front and rear kits, i found it gives you the abillity to tighten it up as its used unlike the rod, plus once as tight as i wanted a tiny dab of thread lock was added behind,
thanks sean , i found that the screws make it stronger too
ment to say i did put a tiny washer inside the frame to just so i didnt crush the resin when tightening it all up, deffinatly works mind, as your pics prove, holds the metal weights up fine, inatially mine would not hold one of gavs resin drums up that i used as a front weight, now holds a white metal mf block and a frame fine
  • 3 weeks later...
