whincebros Posted February 10, 2016 Share Posted February 10, 2016 Anyone got any ideas for taking off the back wheels on a 724? Need to tighten the linkage screws.... Link to comment Share on other sites More sharing options...
Tractorman810 Posted February 10, 2016 Share Posted February 10, 2016 Most uh rear wheels especially the modern stuff is a simple, grip one side tightly ,twist the other side a few times backward and forwards, then pull them off the axel few I have done has glue in them,mostly the older thin hubs on the fords and mf's but the rims hold on a threaded end on the axel,nothing more Link to comment Share on other sites More sharing options...
whincebros Posted February 11, 2016 Author Share Posted February 11, 2016 Perfectly described, thank you! Is it the same with the front ones..? Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 11, 2016 Share Posted February 11, 2016 10 minutes ago, whincebros said: Perfectly described, thank you! Is it the same with the front ones..? no John,dont do that to the fronts as they will snap off,you have to carefully remove the front hubs,that will reveal a screw,undo the screw and the wheel will be free,remove the hubs very carefully Link to comment Share on other sites More sharing options...
whincebros Posted February 11, 2016 Author Share Posted February 11, 2016 Is the front axle removable in one peice? Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 11, 2016 Share Posted February 11, 2016 no John,its not Link to comment Share on other sites More sharing options...
whincebros Posted February 11, 2016 Author Share Posted February 11, 2016 Ok, front wheel has snapped off, is this repairable or have I just made a pigs ear of the whole model? Link to comment Share on other sites More sharing options...
SPN Posted February 11, 2016 Share Posted February 11, 2016 Depends on how it broke. I broke the front wheel on a T6090 last year and was able to glue it back. Be careful not to get glue on the steering joint. Link to comment Share on other sites More sharing options...
