FendtFarmer Posted March 3, 2017 Share Posted March 3, 2017 Would someone do me the pleasure of reviewing and comparing the two machines mentioned above, thank you Link to comment Share on other sites More sharing options...
SPN Posted March 3, 2017 Share Posted March 3, 2017 I'd appreciate that too. Link to comment Share on other sites More sharing options...
Jd6320driver Posted March 4, 2017 Share Posted March 4, 2017 I'll try and do it this weekend as I've both in the collection Link to comment Share on other sites More sharing options...
FendtFarmer Posted March 4, 2017 Author Share Posted March 4, 2017 1 hour ago, Jd6320driver said: I'll try and do it this weekend as I've both in the collection Thank you mate Link to comment Share on other sites More sharing options...
Jd6320driver Posted March 5, 2017 Share Posted March 5, 2017 Both are well built and detailed with their various good and bad points. the Kuhn is a good rake if it is to be displayed on a tractor with a uh style linkage but I've changed my one to fit a wiking style hitch. The Kuhn folds and unfolds as the real one does and also has a working steering axle. The only problem is that the rotors are fixed and don't rotate. The liner also requires modifications but this time to the arms the rotors sit on as they sit too high in the travel position and require a small amount of cutting and the complete stripping of the rake to rectify the problem. The Claas also has moving rotors with positionable arms and a working steering axle Link to comment Share on other sites More sharing options...
FendtFarmer Posted March 5, 2017 Author Share Posted March 5, 2017 Thanks for taking the time to put a review, appricated mate Link to comment Share on other sites More sharing options...
SPN Posted March 5, 2017 Share Posted March 5, 2017 Thanks Hugh. Very helpful. I'm surprised the rotors on the Kuhn don't rotate for the price of it. Link to comment Share on other sites More sharing options...
bluegreen Posted February 10, 2018 Share Posted February 10, 2018 The Claas is nicer, but the Kuhn is still a good model...................................I'm currently deciding which one to buy, but I will want it to go behind a UH style hitch, which will mean some modifications if I buy the claas.....................unless it does fit in place on a UH linkage, although it doesn't look like it. Link to comment Share on other sites More sharing options...
SPN Posted February 10, 2018 Share Posted February 10, 2018 What is the width of each rake in the working position? I think the Claas may be undersized. Link to comment Share on other sites More sharing options...
Paul Palmer Posted February 10, 2018 Share Posted February 10, 2018 Stan,the 2900 is 8 to 9 metres the 2600 is 6.2 to 6.8,wiking made 2 different versions,wiking wise I think they are identical except for obviously the the 26/2900 decals,but I might be wrong,the Kuhn not sure Link to comment Share on other sites More sharing options...
CX820Joe Posted August 19, 2018 Share Posted August 19, 2018 So can you increase the working width/transport height - am assuming that bit that holds the rotors can slide along the arm to an extent - and it looks as though in Hughs photos he has extended the distance they can move along the arm? Link to comment Share on other sites More sharing options...
b_emmons Posted August 20, 2018 Share Posted August 20, 2018 the wiking claas has extending arms Link to comment Share on other sites More sharing options...
