sipher172 Posted January 14, 2019 Share Posted January 14, 2019 I am trying to remove the Wiking wheels in the image below. Anyone have any tips on how to remove the metal washer that is holding the wheel on place. Link to comment Share on other sites More sharing options...
catkom3 Posted January 14, 2019 Share Posted January 14, 2019 Knock the "axle" out with a punch,but make sure it's well supported at the back,. Regards Joe, Link to comment Share on other sites More sharing options...
sipher172 Posted January 14, 2019 Author Share Posted January 14, 2019 1 hour ago, catkom3 said: Knock the "axle" out with a punch,but make sure it's well supported at the back,. Regards Joe, Thanks for the advice. I may have to stick with these wheels. They are steering axles, so it will be very tough to support on the back without damaging the steering system. Link to comment Share on other sites More sharing options...
catkom3 Posted January 14, 2019 Share Posted January 14, 2019 You might get away with gentle tap's then,it's a sort of ring forced onto the end of the axle,holds the wheel in place,but also allows free rotation ,all the early big American artic's used the same method, Regards Joe. Link to comment Share on other sites More sharing options...
Tractorman810 Posted January 14, 2019 Share Posted January 14, 2019 simple enough, level surface and a punch as joe mentioned, last few i removed took one hit ,didnt break anything, its harder to refit them as you will need to fill the wheel hub to give it a level surface to hit against ,otherwise the axel just falls out, each barys as obviously the hubs are all different Link to comment Share on other sites More sharing options...
sipher172 Posted January 14, 2019 Author Share Posted January 14, 2019 Thanks very much, I will give it a crack this weekend Link to comment Share on other sites More sharing options...
sipher172
5 answers to this question
