Part's, Part Number's and their retailers
Deere-est
Here are the two roofing sheet's I have from EMA model supplies.
MPS - 16 to the left and MPS - 19 to the right. I have used the 16 up until now but my go on using the 19 now, more vigorous a profile.
Sheets are round and about 75mm x 300mm. Price GBP 03.36/sheet
On the left-
TBFS - 6P, Styrene Tubing, 4.8mm ext diameter, 3.4mm int diameter x 390mm, 8 pieces per pack, GBP 02.42
On the right-
TBFS - 8P, Styrene Tubing, 6.4mm ext diameter, 4.9mm int diameter x 390mm, 7 pieces per pack, GBP 02.75
Hopefully seeing some pic's make it a little easier to imagine them in situ. Anyone else got some similar bits and bobs and info to add to the Topic? I reckon those Trelle Wellies woul look the biz on your new tattie box trailer Mark. That said I want to put them on an AS trailer of mine but how do you get the original wheels off without breaking anything? ???
Cheers TM, 10% discount on your next order mate.  ;D
As long as your total order value exeeds ?15,000.
15000,what do you think my name is doc palmer or q?? :D :D :D :D :D :D :D :D
no what other bits are you casting,? i have the tool box on the front of the 2640 2wd and it really does add to it,only found it by accident when i went for a tow hitch
Great idea Tris... what diameter are they then... and I had the same trouble - I recron it will be a new axle as well as I can't seem to get them off without bending the axle as well - anyone know how (melt them with a soldering iron maybe  ???)
Thats what I feared, bending the axle. I want to keep the wheels for other things so a soldering might be a bit sid vicious.
The Trelleborgs are 36mm dia x 20mm wide. Not sure if that is including tyres as I havnt got mine to hand.
http://www.farmmodels.co.uk/spare-parts-farmmodels.html
