Help wanted....To wide cultivator....
Looks silly, dosent it? I took it to far maybe...
possible directions:
- Take three more and put behind them....
- Make some sort of wagon with a hitch on it...
- disable it and start all over again...
Where do I go next??? any ideas?
been looking at this convo for a while now bv78. the 3 together would put a terrific strain on the beams depending on it's use of course, i thought two would be enough with a crumbler bar / clodbreaker rollers behind.
nice set though,  a double set & clodbreakers would give it some strength but it would then have to be a semi mounted implement as the weight would make most tractors dance .
looks good, like to follow this convo :)
I am thinking of building some kind of wagon to il, like the base of the new lemken from siku. Therefrom you can raise or lower the cultivator. But how do I built a good wagon?? Is it something who makes a good base?
The end will come of I think... I feels like overkill tho have thoose attached.
i like that lots nath is that one of seans drills ?
Very easy to make Marcus. 2 cultivators glued together is pratically all it is. Although I did add  some bits of plasticard on the outer sections to make it a bit stronger and added a siku linkage adaptor and drawbar for towing and mounting implements ;) ;) ;)
The MF drill is one I made Marcus, as I had 2 lying around doing nowt ;) ;) ::)
Could always double them up, so one runs behind the other, like this ???;)???;)
Looking good!!! I am seriosly thinking of doing that, just to get better proportions. And then make some sort of drawbar on it. But I have to think how to do it effective.
if i ever get another cultivator i'll certainly give it a go nath, that certainly hits the spot for me  :) i would assume it's fairly heavy though ?
believe me sean if i ever get two the same colour ,you'll be the first to know about it ,when you open them in the post ;);D
i cut up two siku combi drills last night to make a 4mtr version but seem to have lost the plot & have lots of bits , but these cultivators from bennyv & nath are within my skills ..........................i would think  :-\
you lost that a long time ago or was that to do with your mum droping you on your head as a bady
 Share
