Paul Palmer Posted November 23, 2020 Share Posted November 23, 2020 Hard to tell Rob,if the cab can be made level,need a head on shot of the model as well,also were circled in white,looks like that bracket might need altering,more pictures would help Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 23, 2020 Share Posted November 23, 2020 6 hours ago, robbo said: I first saw this model at the Zwolle show a couple of years ago. At the time I was quite excited about getting one as I had driven a Fiat 850DT whilst I was still farming. However, when I saw it I was most disappointed with the cab that slopes backwards instead of being level. I don't know what went wrong as almost all of the models coming from Toys-Farm are fantastic. Does anyone know if the cab tilt can be corrected? i suspect it could be levelled out mate , as discussed at zwolle, the key would be to see one out of the box, at a guess raising the rear would be easier, looking at it , to drop the front will prob mean cutting the cab frame ,and adjusting and floor parts which may make the cab frame look wrong .having never seen. a real one with this cab,i wouldnt know if the glazing at the front is right or not size wise . Link to comment Share on other sites More sharing options...
catkom3 Posted November 23, 2020 Share Posted November 23, 2020 Does the U H version look high as well.?? Regards Joe. Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 23, 2020 Share Posted November 23, 2020 i thought both versions were uh joe, got a feeling both were commissioned by toy farms i think Link to comment Share on other sites More sharing options...
catkom3 Posted November 23, 2020 Share Posted November 23, 2020 12 minutes ago, Tractorman810 said: i thought both versions were uh joe, got a feeling both were commissioned by t toys i think Cheers Sean, I figured the one Mike had was limited edition, But you are probably right. Regards Joe. Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 23, 2020 Share Posted November 23, 2020 4 minutes ago, catkom3 said: Cheers Sean, I figured the one Mike had was limited edition, But you are probably right. Regards Joe. i think there maybe 4 in total, two without cabs,with white and orange wheels. been a while since i saw any to be honest, but do remember having the discussion with rob at zwolle on them. Link to comment Share on other sites More sharing options...
catkom3 Posted November 23, 2020 Share Posted November 23, 2020 3 minutes ago, Tractorman810 said: i think there maybe 4 in total, two without cabs,with white and orange wheels. been a while since i saw any to be honest, but do remember having the discussion with rob at zwolle on them. Well done memory man there are indeed 4, https://www.farmmodeldatabase.com/en/models/search/fiat/universal-hobbies/1-32/tractors.html Regards Joe Link to comment Share on other sites More sharing options...
robbo Posted November 24, 2020 Author Share Posted November 24, 2020 I was looking at the cabbed versions at Zwolle and intending to buy both but, the slope put me off although I have not given up hope that one day they may be corrected. I have never seen the real one without the cab so they didn't interest me. Link to comment Share on other sites More sharing options...
robbo Posted November 24, 2020 Author Share Posted November 24, 2020 It was this cab style I was looking for in particular, this was the 1000DT that I already have a model of but we also had an 850DT that I was looking for Link to comment Share on other sites More sharing options...
robbo Posted November 24, 2020 Author Share Posted November 24, 2020 This is the cab on the Replicagri 1000DT model, the front screen is at bonnet level rather than raised, I suspect that is the problem. I wonder if the cab would be interchangeable? Link to comment Share on other sites More sharing options...
Tractorman810 Posted November 24, 2020 Share Posted November 24, 2020 Different arches on the one you had as well , i guess if your after a rough look you could convert the uh ones, build new arches and adjust the cab to fit ? Would be expensive to buy the uh and replicagri one to see if they could be swapped Link to comment Share on other sites More sharing options...
robbo Posted November 24, 2020 Author Share Posted November 24, 2020 20 minutes ago, Tractorman810 said: Different arches on the one you had as well , i guess if your after a rough look you could convert the uh ones, build new arches and adjust the cab to fit ? Would be expensive to buy the uh and replicagri one to see if they could be swapped Well beyond my limited capabilities that's for sure Link to comment Share on other sites More sharing options...
