new holland driver Posted June 18, 2007 Share Posted June 18, 2007 we at willam long frams a going in whit anthor farm and the trators are on there way we are going to have two nh tm 155 fro the run around tractors and 8330 on a seven furrow and pres but the big row is whit the drill tractor do you lot think the new jd 7530 (180) horse power will pull a 4m verdsta or not Quote Link to comment Share on other sites More sharing options...
Kris Posted June 18, 2007 Share Posted June 18, 2007 deffinately would easily pull it Quote Link to comment Share on other sites More sharing options...
new holland driver Posted June 18, 2007 Author Share Posted June 18, 2007 are shore on sand steep hils and wet heavy clay Quote Link to comment Share on other sites More sharing options...
Kris Posted June 18, 2007 Share Posted June 18, 2007 ive seen one pulling a 4mtr drill on holderness clay Quote Link to comment Share on other sites More sharing options...
new holland driver Posted June 18, 2007 Author Share Posted June 18, 2007 what speed was he doing as verdesta have hold us we need to be pulling at 12 to 14 k Quote Link to comment Share on other sites More sharing options...
Kris Posted June 18, 2007 Share Posted June 18, 2007 im not sure as wasnt near enough really but im pretty sure it was a 30 series but may have been 8530 Quote Link to comment Share on other sites More sharing options...
new holland driver Posted June 18, 2007 Author Share Posted June 18, 2007 ther is a big difrets between a 8530 which is long nosed jd and a 7530 which is 6920 whit a bigger engine Quote Link to comment Share on other sites More sharing options...
Gav836 Posted June 18, 2007 Share Posted June 18, 2007 180hp should pull it easily Rich, they are pulling a 4m Vaderstad with a NH TVT175 where I used to work at speeds of 12-14kph Quote Link to comment Share on other sites More sharing options...
Kris Posted June 19, 2007 Share Posted June 19, 2007 180hp should pull it easily Rich, they are pulling a 4m Vaderstad with a NH TVT175 where I used to work at speeds of 12-14kph told ya ha ha! ;D ;D Quote Link to comment Share on other sites More sharing options...
pobbrennan Posted June 19, 2007 Share Posted June 19, 2007 We use a 7530 to run a 4M Accord DF1 and it handles it very comfortably. As you have New Hollands already the new 7000 series New Holland would be more power for less money, may be a slight bit heavy for you though. Quote Link to comment Share on other sites More sharing options...
sparrow legs Posted June 19, 2007 Share Posted June 19, 2007 180hp will pull it fine, a customer bought a 2wd mf 3095 to pull a 4m vaderstad in holderness as you guess it wasnt up to the job but 150hp plus will pull 4m no sweat masseyrule, get an eye sight test , a 7530 looks nothing like a 8530 were was it, i will probably know the farmer, did you say your based in hedon? Quote Link to comment Share on other sites More sharing options...
Kris Posted June 19, 2007 Share Posted June 19, 2007 im based in headon but saw it along the m62 and i was wearing ma contacts and its was quite a way away Quote Link to comment Share on other sites More sharing options...
sparrow legs Posted June 20, 2007 Share Posted June 20, 2007 im based in headon but saw it along the m62 and i was wearing ma contacts and its was quite a way away i was topping the grassed areas on leaf sail estate in hedon last week was on a mf 6180, im setting up on my own flailing with my jd 3040 and spearhead flail, ACS the company name, look out for me, getting tractor sign wrote asap Quote Link to comment Share on other sites More sharing options...
Kris Posted June 20, 2007 Share Posted June 20, 2007 pics of these tractors and i will definately look out for you Quote Link to comment Share on other sites More sharing options...
new holland driver Posted June 20, 2007 Author Share Posted June 20, 2007 it was between the nh and jd the jd only won as it the boss how is bigjd fan drill drive is a grump about and wont drive it ; Quote Link to comment Share on other sites More sharing options...
MJB1 Posted June 20, 2007 Share Posted June 20, 2007 it was between the nh and jd the jd only won as it the boss how is bigjd fan drill drive is a grump about and wont drive it ; be out of a job then won't he Quote Link to comment Share on other sites More sharing options...
deere 7810 Posted June 20, 2007 Share Posted June 20, 2007 i know of a jd 6920 that pulls a vaderstad 4m drill so am sure it will be up to the job! Quote Link to comment Share on other sites More sharing options...
TS135A DRIVER Posted June 20, 2007 Share Posted June 20, 2007 This whole machinery sharing business sounds like a recipe for huge problems at busy times and also when things go wrong with equipment there will be the who is to blame for it breaking down due to neglect or misuse Not a great idea in my opinion Quote Link to comment Share on other sites More sharing options...
Jez Posted June 20, 2007 Share Posted June 20, 2007 we at willam long frams a going in whit anthor farm and the trators are on there way we are going to have two nh tm 155 fro the run around tractors and 8330 on a seven furrow and pres but the big row is whit the drill tractor do you lot think the new jd 7530 (180) horse power will pull a 4m verdsta or not Make sure you get them to show you the 'soft shift' setting in the command centre, with that switched on it will not revv up and speed up the fan when you change down a gear at the end of a run. Excellent feature, has the NH got that? Quote Link to comment Share on other sites More sharing options...
sparrow legs Posted June 20, 2007 Share Posted June 20, 2007 pics of these tractors and i will definately look out for you all should be on here in different places, my jd, works 6180 and 6270, we do all the council flail mowing for hull city council (i dont, did one season and refused to go back, damb townies) Quote Link to comment Share on other sites More sharing options...
new holland driver Posted June 23, 2007 Author Share Posted June 23, 2007 be out of a job then won't he no he has a been there to long they wont get ride of him but he will have to drive the sprayerand the spud lifter Quote Link to comment Share on other sites More sharing options...
