ihatepoundland Posted September 3, 2007 Posted September 3, 2007 Fairly rare to see stubble disc'd, usually ploughed straight in - and probably the biggest tractor in the area to boot Missing photographing the harvest already, bring on the maize. And on yonder hill - Quote
britainsnut Posted September 3, 2007 Posted September 3, 2007 Looks like it was a family day out for the driver :D Quote
ihatepoundland Posted September 3, 2007 Author Posted September 3, 2007 Haha, indeed, mother and baby arrived just after I stopped to take photographs, she said he likes to have a tractor ride before bedtime Quote
ihatepoundland Posted September 4, 2007 Author Posted September 4, 2007 Ah ...OSR is an unknown to me Quote
ihatepoundland Posted June 17, 2008 Author Posted June 17, 2008 Not discing but sowing rape Bit odd....but this is what grew Quote
Gav836 Posted June 17, 2008 Posted June 17, 2008 If you look at the side on view of the tractor/subsoiler you will see that the seeder is empty, more likely that it was just ripping up the ground before the drill went in Quote
Kris Posted June 17, 2008 Posted June 17, 2008 If you look at the side on view of the tractor/subsoiler you will see that the seeder is empty, more likely that it was just ripping up the ground before the drill went in Give that mana biscuit. Well spotted though. Quote
FB Posted June 21, 2008 Posted June 21, 2008 he has eagle eyes!!!, i assume you would see a kinda shadow then if there was seed in the tank? \ Quote
ihatepoundland Posted June 22, 2008 Author Posted June 22, 2008 But then again, it couldn't have been full at the time because of the crop that appeared, quite a big hint after the event Quote
James Earwaker Posted June 22, 2008 Posted June 22, 2008 Bit odd....but this is what grew Nice big wild oat there, hopefuly will get walked throw before harvest If you look at the side on view of the tractor/subsoiler you will see that the seeder is empty, more likely that it was just ripping up the ground before the drill went in Correct me if im wrong but i recon with those Simba machines that have the seed unit attachment on have the meetering wheel running behind the packer and i cant see 1, so cant be seeding if he wanted to??? Quote
