Jez Posted September 24, 2007 Share Posted September 24, 2007 Available from all good hobby shops near you: Cost me ?2.99, must be worth that for the effect you get. The only problem is that the card sometimes doesn't pull through square so the ripples are a bit off scew. I will give you a bit of a demo if I can in the next pics. Quote Link to comment Share on other sites More sharing options...
Jez Posted September 24, 2007 Author Share Posted September 24, 2007 imply feed the silver sheets in and you get..................? Quote Link to comment Share on other sites More sharing options...
Jez Posted September 24, 2007 Author Share Posted September 24, 2007 corrugated sheets Quote Link to comment Share on other sites More sharing options...
Jez Posted September 24, 2007 Author Share Posted September 24, 2007 or you get green sheets............. Quote Link to comment Share on other sites More sharing options...
Jez Posted September 24, 2007 Author Share Posted September 24, 2007 Best thing is you get the ripple or corrugation on both sides: Hope this is of some use to some people. Quote Link to comment Share on other sites More sharing options...
Lord Ferguson Posted September 24, 2007 Share Posted September 24, 2007 What a brilliant device... I bet it will be used by many on here.... I wonder if it would do some thin soft aluminum... or thick foil even \ Quote Link to comment Share on other sites More sharing options...
Leakeyvale Posted September 24, 2007 Share Posted September 24, 2007 can the ripple effect be modified? Made smaller or larger? Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 24, 2007 Share Posted September 24, 2007 tha looks intresting, may have to look into one of those at some point Quote Link to comment Share on other sites More sharing options...
rich.new holland Posted September 24, 2007 Share Posted September 24, 2007 i got one of those but it can take wider pieces of card but it cost me 9.99 :'(i wish i saw that one for 2.99 as i havent used it that much ,well not enough to make it worth it anyway \ Quote Link to comment Share on other sites More sharing options...
Massey Boy Posted September 24, 2007 Share Posted September 24, 2007 we had one of them at school good pice of kit Quote Link to comment Share on other sites More sharing options...
Jez Posted September 24, 2007 Author Share Posted September 24, 2007 No it nearly broke when i put two pieces of card through it. There is nothing stopping someone trying to make one from wood if you were really skilled? No the ripples are set to about 3mm wide Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 24, 2007 Share Posted September 24, 2007 3mm wide not to far of scale that, i use 3mm ema plasti card so its good, Quote Link to comment Share on other sites More sharing options...
Deere-est Posted September 24, 2007 Share Posted September 24, 2007 I like that a lot, could bring to an end my hunt for corri card as good as Smallclaas uses. ... can't find that over here anywhere. Thanks for posting Jez, very useful inof mate. Quote Link to comment Share on other sites More sharing options...
Jez Posted September 25, 2007 Author Share Posted September 25, 2007 I like that a lot, could bring to an end my hunt for corri card as good as Smallclaas uses. ... can't find that over here anywhere. Thanks for posting Jez, very useful inof mate. Agent Jez Mission 4 - Closed My next plan is to get another and glue them together so it will take wider pieces of card. Quote Link to comment Share on other sites More sharing options...
FB Posted September 25, 2007 Share Posted September 25, 2007 looks great!!, as Marky said, could you use thin Ali strips??....guess they might be expensive though \ ??? Quote Link to comment Share on other sites More sharing options...
Lord Ferguson Posted September 25, 2007 Share Posted September 25, 2007 looks great!!, as Marky said, could you use thin Ali strips??....guess they might be expensive though \ ??? I can get some Ben... you buy the machine... I supply the metal mate.... I reckon some real thin ali will be just the job Quote Link to comment Share on other sites More sharing options...
FB Posted September 25, 2007 Share Posted September 25, 2007 I can get some Ben... you buy the machine... I supply the metal mate.... I reckon some real thin ali will be just the job sounds like a plan! ;D Quote Link to comment Share on other sites More sharing options...
Deere-est Posted September 25, 2007 Share Posted September 25, 2007 This sounds good lads. Get onto it, pronto! Quote Link to comment Share on other sites More sharing options...
Tractorman810 Posted September 25, 2007 Share Posted September 25, 2007 I can get some Ben... you buy the machine... I supply the metal mate.... I reckon some real thin ali will be just the job sounds a good plan, can see silos appearing now from that stuff if it works Quote Link to comment Share on other sites More sharing options...
Deerepower Posted September 28, 2007 Share Posted September 28, 2007 got one of these today and having fun with it got it form a shop called "the works" for ?1.99 Quote Link to comment Share on other sites More sharing options...
FB Posted September 28, 2007 Share Posted September 28, 2007 got one of these today and having fun with it got it form a shop called "the works" for ?1.99 wheres that then?? Quote Link to comment Share on other sites More sharing options...
Deerepower Posted September 28, 2007 Share Posted September 28, 2007 the shop is called "the works" it's a cheap book/ stationary shop it was ?2.49 put scanned at ?1.99 so a bargin. www.theworks.gb.com Quote Link to comment Share on other sites More sharing options...
FB Posted September 28, 2007 Share Posted September 28, 2007 didnt know they had one in Cambridge ....well i dont go down that street but looks like a new one opening soon Quote Link to comment Share on other sites More sharing options...
Deerepower Posted September 28, 2007 Share Posted September 28, 2007 at least you know where to get one from now Ben Quote Link to comment Share on other sites More sharing options...
FB Posted September 28, 2007 Share Posted September 28, 2007 at least you know where to get one from now Ben yep, might try next week...trouble is thats where all the students hang out :D Quote Link to comment Share on other sites More sharing options...
britainswomble Posted September 28, 2007 Share Posted September 28, 2007 I can get some Ben... you buy the machine... I supply the metal mate.... I reckon some real thin ali will be just the job What about drinks cans as a supply of sheet aluminium. Watch yer fingies on it though....cos it dont arf cut. Cutting it without wrinkling the edge might be a problem so I would suggest a paper guillotine. The type with the long arm would be better than the wheel type. Er....jus tryin to be elpful. Quote Link to comment Share on other sites More sharing options...
Jez
32 answers to this question
